Can someone explain to me how a keg works?
Discussion in 'The Lounge' started by protechk5, Jan 11, 2006.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    How does the beer come out the top in on keg when there is hardly any beer left? There must be a tube or something that goes to the bottom. Also does anyone know if they even clean them? We have turned in some kegs that have been sitting around forever, when I pressed the ball down to see if there was any pressure left, the worst smell came out, and thats what got me thinking of how they clean the kegs?? Anyone?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    No clue but I have one almost new in the shop waiting to be cut into a bbq grill.
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i dunno, but ive got one at my house, its actually in my closet right now...
  4. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    i'd be happy to research it for you, just send a couple of full ones my way and i will let you know in a couple of days
  5. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    kegs are pressurised (hence the pumping) Keeps the beer flowin
  6. muddysub
    Jun 23, 2001
    10,451
    489
    what kind of PSI is inside a keg for it to put out beer.... i wanna hook mine up to my compressor. i got a feeling im gonna have to turn the reg WAY down
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If it straightens out the wrinkles in the side of the can, it's probably too much pressure.:haha: :haha: :haha:
  8. CustomChevy
    Jun 29, 2005
    4,328
    no idea on psi, but i assume its not to low.
    anyone who's pumped a neer empty keg knows it takes alot. AND Bars use tanks of compressed co2 to keep taps flowing.
    generally if you get foamy beer, you got to much pressure.
  9. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    idk, we had the wild idea of shoot a empty keg with a highpower if we ever do it ill get pics, as far as cleaning them out, someone told me onetime that the ball comes out somehow, anytruth to it im not sure.
  10. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    I found an empty 1 gallon keg in my front yard last month... It's got a few dents, and it's for Grolsch premium lager.......... Now it's in my room with a Poinsettia on top of it :D
  11. muddysub
    Jun 23, 2001
    10,451
    489
    first of all, you FOUND a keg in your front yard? huh? and using it as a decoration is awesome!
  12. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I found:whistle: a keg bbq grill.
  13. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Kegs have a valve on top connected to tube called a spear that goes down from the valve on the top to the bottom of the keg. Pressurising the top of the keg forces the beer up the spear and into your glass. C02 is the best way to pressurize a keg. It also carbonates the beer giving it more fizz. Using regular old air to pressurize a keg will just make the beer go flat.
    Beer does not come pressurized in a keg. There is a little natural pressure but you need about 10 psi of CO2 to make it flow the best.
    Kegs are cleaned at the brewerey. The valve on the top is removed. It is held in place with a snap ring. Need a high tech special tool to remove it.
    Then
    They are high pressure washed inside, sterlized then inspected with fiber optics. Kegs gotta be super clean when filled, or the beer will go bad.
    But
    You really shouldn't worry about all the high tech mumbo jumbo of beer kegs.
    All you need to know is how to pour the perfict glass of beer. Preferably large and cold:D
  14. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    My roommate made a kegerator and if you want to keep the keg for any length of time, you have to use co2 and not compressed air, or else the brew will go bad. No reason you cant use air though, as long as you drink all the beer then and there.
    Logically, the keg has an air valve at the top, and a hose extending to the bottom. The pressurized air pushes the beer down to the bottom of the keg and up the hose to the tap. Any aerosol can works the same way.
  15. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,859
    282
    Truckee, CA
    You put a tap on it, pump the tap, dispense beer into chosen container wiht the little hose.
    Then you drink it
    Repeat until you forget what to do and need to reference this thread :bow:
  16. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    depending on the beer, regulator and other factors, the required psi varies. I never had enough time to fine tune my keg before I left my kegerator at my brother's place. 10psi was a bit high for me, but I needed to replace the spigot as it leaked a bit. Another reason to use C02 as opposed to air is that CO2 is generally "clean" and air will have any bacteria or microbes that will grow in the beer to make it skunky faster. But we never had any problems finishing kegs. We were a drinking team with a rugby problem. ON! ON!
