Can someone explain?
Discussion in 'The Garage' started by mud hungry, Jun 1, 2005.
  1. mud hungry
    mud hungry 1/2 ton status
    Oct 4, 2004
    506
    Haydenville, Massachusetts
    Can someone explain what both a stall converter is, how it works as well as what should be used for a dd, mud runner, and light rock. and could you explain how what and when to use a rev limiter. Thanx
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I would get a stall that is just slightly higher than stock if you do more mudruning if you do more rockcrawling go with a stock one higher stall speed also creates more heat so put a tranny cooler on
  4. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    rev limmiter is like preventive maintanance. If something in your drive train breaks while you are hard on the throttle (ie: short drive shaft on a divorced set up, or a dry-coupler) It can keep a bad day from getting much worse.
  5. mud hungry
    Oct 4, 2004
    506
    Ok I guess that I will not need a stall converter seeing how I will be using a NV4500. Now about the rev limiter what would be a good limit. again be use as above. Is it in the distributor or somewhere else in the engine?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Rev limiter is usually in your aftermarket ignition box , either plug in like a fuse or adjustable some how .
    The limit should be under what is reccomended for your engine combo for safety , I.E engine redline .
