Can someone help me fix my a/c-heater? Please!!
Discussion in 'Rocky Mountain Region' started by cochino12, Dec 1, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    I cant figure out why I only get floor heat, I have searched and tried all the fixes I have found on the threads here and I cant get it to work. Does anyone know how the hell to fix this damn thing. /forums/images/graemlins/1zhelp.gif
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Sure, first, fill out your profile. What year? any mods, or stock heater config.? Some Gm's use cable linkage and vacuum to control heat flow and some use just vacuum system...
  3. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Sorry, its an '83 w/ac all stock.
  4. cwn anwyn
    cwn anwyn 1/2 ton status Premium Member
    Oct 30, 2002
    1,268
    6
    Falcon CO
    When I fixed my 84 it was a vac leak. Check the hose from the firewall. On mine it was a narrow hard plastic line with a clear hose end that plugged into the manifold vac source between the carb and dist.
    Z /forums/images/graemlins/k5.gif
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Have you pulled the heater/vent control panel from the dash? Do that first, check all cables, and the metal clips they fit into, make sure they're connected on both ends, and move freely. start there. Let us know what you find.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Are you still coming up on Saturday? If so, I can take a look at it for ya then. /forums/images/graemlins/cool.gif
  7. cochino12
    Dec 23, 2003
    563
    Parker, Co
    I'm going to try, thanks I'll let you know /forums/images/graemlins/thumb.gif
