Can someone help me with a GM part number- Tranny cooler
Discussion in 'The Garage' started by FWP, May 13, 2002.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I've looked around and haven't been able to find a GM part number. I want the biggest, baddest, low pressure drop factory tranny cooler that GM makes, say off a 1 ton hauler truck. Any ideas?
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    In about 96-97ish, G.M. was running a "Stacked-plate" design. looking at it, it had air-flow paths and fluid flow paths, that criss-crossed from one-plate to the next. The upper plates flowed one-way, the lower plates flowed in the oposite drction. (not like the cheeper versions, that stacked the same plates, one-top of other)
    That style cooler is by-far the best.
    Also, It takes up less-space (more air-flow into the radiator) and, it's not as restrictive as the other-stacked plate designs.(again, cleaner air flowing into the radiator).
    I would look at B&M, I'm pretty sure thier high-end coolers are the same style.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I looked into GMs coolers they were way expensive. I did not see any diference between B&Ms coolers and the GM stock replacement for my cooler.
    I an running The <a target="_blank" href=http://www.bmracing.com/noflash/products/acc_tranCoolers.html> B&amp;M Super Coolers</a> for my Trans and Engine oil. They work very good.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have a factory oil cooler on my 90K5. It is exactly the same as the B&amp;M 28000 cooler installed for my transmission cooler.
  5. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    I forgot to also add that GMs coolers and the B&amp;M coolers are made by the same company. Both coolers have "Long Manufacturing" stamped on them. The B&amp;Ms are about $100 less. Than if you go and buy one from the dealer.
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Thanks guys, I just ordered the 28000 lb from Summit.
