can someone identify this a/c part (pic inside?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 75K5, Jul 30, 2003.
  1. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    This is on the back of the climate control unit, and it's bad. I don't know what to call the parts store to ask for, and the guys at the local autozone had no idea.
    Brian
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    If I understand correctly this cameoff the back of the control head (the thing on the dash that you move to select AC Max, Norm, Bi, Vent etc.). I don't reconize it as being from the '70s, but either way it is the vacuum selector switch. Most parts houses don't carry them. I've only found them at O'riellie's and Car Quest do. Most of the time it is a dealer, junkyard, or restoration store part.
    Hope this helps.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The guys at Autozone had no idea because that is a dealer only part. You're not going to find that at any parts store.
  4. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    yes, that helps out greatly. I am going by carquest tomorrow to pick up a new evaporater, so I'll bring it along. Can't wait to have AC in the beast!
    Brian
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Good luck. Let me know if they have it and the part number
  6. blazer74
    blazer74 Member Premium Member
    Oct 18, 2001
    1,164
    80
    Brighton Tn
    The part number is what you see on the unit, 340427 or 340428. Chances are you won't find it new. I found mine at a salvage yard. 74 to 77 chevy truck with A/C.
    Why do you think it is bad.
  7. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    there is a dead spot in the a/c controls, and sometimes when you slide to AC you can hear the compressor clutch engage, sometimes it doesn't. If you wiggle the switch it will work.
