Can someone identify this engine?
Discussion in 'The Garage' started by Zeus33rd, Jun 6, 2002.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Small block
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Ok, Dumb question maybe, But what did you look at to tell? I was kinda going by what I could see of the exhaust manifold and spark plug locations....
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Look at the valve cover, a big block has a wider cover. also the small block has 4 bolts holding it on, 2 on top 2 on the bottom. the valve covers on a big block have 3 bolts on the top and 4 on the bottom.
    a big block also has a by-pass line from the intake manifold to the water pump.
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Aren't the bbc exhaust ports evenly spaced whereas on a sbc the center ports are next to each other?
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    correct, til you get into the newer style small blocks they went to staggered valves like the big blocks.
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Yeah...BB ports evenly spaced......SB center ports next to each other. I thought thats what I was seeing.....so I figured it was a SB......Hmmmmmm.....I can get the truck this engine sits for under $300....It's a 1 ton...but 2 wheel drive....decisions decisions....
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Except on a 427, it has the same size valve covers as a SBC, not sure about the number of bolts though......
  9. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Man that's a new one on me. Every 427 I have ever seen has the same size valve cover as the 454, 396, etc. Where did you see one with small block size valvecovers ?
  10. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    That would be my thought, isnt a 427 just a 396 with a 454 crank? or something along those lines. It should look more or less the same as any other BB depending on the heads, etc thats on there.
  11. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    You are close, but it is just the oposite. A 427 is a 454 block with a 396 crank if you want to look at it that way.
    Mike
  12. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    And a 454 was a stroked 427.
  13. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Small Block, Look at the Exhaust Manifold. Center Dump for #s, 4 and 6. No 427"s don"t have the same size Covers as a Smallblock!
    As a Chevrolet Certified Technician, since the Dawn of time, I can Vouch for this.
  14. bigugly
    bigugly Newbie
    Jun 6, 2002
    4
    Mile High Colorado
    If you get the info on the right front bank in front of the head, you, can go to this web page and id it. http://www.nastyz28.com/decode.html this guy has alot of info on Chevy engines. I went through about 2 reams of printer paper just copying the info for the trips to the boneyards. With this info I pick up a 300 hp 350 ci corvette motor for $100.00. The guy is good.
    L8r,
    Jim in The BigUgly.
  15. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    No dice. Maybe you saw a 427 small block. It's bored & stroked like a mutha. But a 427 BB is a canted valve motor as is a 396-402-454-502 ect...
    Jim
