can someone reccomend a tranny cooler?
Discussion in 'The Garage' started by wraenking, Sep 9, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i want to get a decnet one so i dont blow out my front pump seal again!!
    thanks boys
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    A stacked plate design, the biggest weight rating you can find basically.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    B&amp;M Tranny Cooler....The <font color="red"> BMM-70264 </font> is the one I'm running and have never had any issues /forums/images/graemlins/thumb.gif
  4. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    thanks guys!!
  5. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Yeah, Mork, I mean Tazz is right.
    That's the same one I have in my Burb as well, keeps the OD nice and cool.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Hayden ones arent bad either. Get the bigget stacked plate one you can fit. Cools better and is more durable than the usual finned one.
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I used an 11" by 11" stacked plate type cooler like this one: cooler link It's been to Baja and back w/ no issues.
    FWIW B&amp;M is a repackager of coolers. Odds are good that you can find the same cooler elsewhere for less $$$
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    how did you plumb it? did you keep the rad. cooler and use both?
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, i'm still using the rad cooler and I'm using both /forums/images/graemlins/thumb.gif
  11. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    i got one from empi/bugpack that is a 96 pass stacked plate cooler with a built in electric fan, roughly $160 shipped from www.OffRoadWarehouse.com. It has 1/2'' female npt fittings at the bottom and they sell adapters to go to different hose sizes if you already had lines.
  12. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    A thot on this, which is first can make a BIG difference. If you plumb thru the rad cooler first then you're not getting the full benefit of the aux. cooler.
    If you plumb thru the aux. cooler first then you're getting the full benefit of that cooler, plus if it's cold out you're warming the fluid up which aids in getting the trans up to operating temp quicker. Just beware that plumbing it this way works the fluid harder so your fluid's service life will be shorter.
    Ideally you'd plumb it with an in-line thermostat b4 the radiator cooler. That way the aux. cooler is only in the system when you need it.
    VDO &amp; NAPA both sell thermal switches with a variety of set points. These switches close a connection to ground at a certain temperature. I welded a bung into the pan and put a 265*f switch in it. Once I finish the wiring it will turn on a warning light at that temp. Nice to have some warning that the trans is aboot to give up w/o having to monitor another gauge.
