Can someone take a look at Carb.
Discussion in 'The Garage' started by Brocky, Aug 22, 2005.
  1. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
  2. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    Computer controled carb usually found in early to mid 80s GM's
  3. Brocky
    May 22, 2005
    1,170
    Now where do I start making a good carb? :doah:
  4. dyeager535
    26,980
    You are asking if you can use it on your '78?
    Yes, you can use it. It will run "full rich" (primary rods all the way out, all the time) without being hooked up to a computer. From my experience, the engine will run, but you will knock your mileage down to around half of what it should be, and that amount of fuel being dumped isn't good for the engine.
    So in other words, it will likely let your engine run, but it's not right. Go get a non-CCC carb.
    I think the newer design (one in the front of that pic) is slightly better, it seems you get a bit better control over how it runs. A bit more "refined" if you want to put it that way, even though it has a few more emissions related vacuum ports on it.
  5. Brocky
    May 22, 2005
    1,170
    I choose the second one with manual choke, just finished putting ti on and works perfect. Thanks for the response. I gonna get the first one rebuilt and Sell the Edelbrock.
