Can someone tell me what 12-bolts will bolt up to my 69 K5?
Discussion in 'The Garage' started by chevy_muscle, Jan 6, 2005.
  1. chevy_muscle
    chevy_muscle 1/2 ton status
    Mar 16, 2004
    Murphy, tx
    I'm wondering what donor trucks I can get a 12-bolt from that will bolt right up to my '69 blazer.
    I'm looking for a posi rear end and mine is open.
    Here's a link to my wanted post: http://coloradok5.com/forums/showthread.php?t=125325
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    Phoenix, Az
    The factory POSI would probably be the gov-loc which does not have a good reputation. Another issue would be to keep the gearing the same in both the front and rear axles. Since you were lucky enough of get an open 12 bolt , you can just buy a lockrite {$220 at jegs}, put it in and your set.:D
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    central IL
    if its 4x4 k5 69-72 then only 72 older 4x4 or any years rear 1 ton axles will fit
    69-72 4x4 are 40" spring perch centers
    these are 40 centers too:
    - 1 tons(C/K-30's) '60`s and up years(k-30 did not exist til 77)
    -'69-72 k5's(4x4's only)(all 69's were 4x4)
    -68-72 longhorns(C-20 C30 trucks with fleetside bed, these were built on 1 ton chassis)
    -'69-70 9 foot steps(these were built on 1 ton chassis also)
    shock mounts changed 73-up. but thats no biggie, yank yank
    range of ratios you will find under the above models- except 69-72 K5's in which were 3.07/3.73:
    no gov lok until in the 70s sometime, the 67-72 trucks were good old reliable strong clutch pack limited slip :D you can still find them around although most all of them are with 3.07 ratio,
    dana 60 were powrlok
    eaton 52 and 72 and 110 were no-spin i believe
    and there was one more posi unit under gm trucks i forgot name and applications, id have to go and look
    good lcuk
