Can someone write a NO B.S. faq about 52" springs?
Discussion in 'The Garage' started by cochino12, Jan 13, 2005.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    Please?
    I have been searching for two days looking for info on a 52" spring swap. It also looks like I am not the only one looking into this. Seems like a lot of people have opinions but not a lot of people have done the swap. I want an affordable 4-5' lift for the rear and cant use a shackle flip, and I cant seem to find actual info for the rear.
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    well, the 52 swap is for the front... you should already have 52's in the rear...
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You have 3 choices to get 4-5" lift in the rear. Shackle Flip, lift spring, or block. I recommend against blocks and you said shackle flip is out. I just installed rear lift springs in my truck Wednesday (replaced add a leaf & block combo) and it rides alot better.
    For a 4" lift I recommend a 6" spring minus 1 leaf. For a 5" lift I recommend a 6" lift spring with the overload removed or deal with the extra 1" of lift.
    Harley
  4. cochino12
    Dec 23, 2003
    563
    Parker, Co
    ha ha well maybe thats why I cant find the info I need!! :D
  5. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I have been looking for something on this as well, but no luck so far. Jekbrown is about to do the swap and I believe he mentioned something about doing a write-up on it while he was doing it...
    Might want to send him a PM or whatnot to see if thats still the plan or what.
    I know I plan on doing the swap to my truggy so if he hasnt done the write-up by then, I guess it will be my opportunity.
    -Ryan
  6. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    my swap is gonna happen this sunday, along with the 63" rear swap! planning on shooting lots of pics:D i want to do a write up just need help as i write like a 3rd grader :ears:
  7. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    so what did you decide to use, 52's or 56's??
  8. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Did you guys look at my website? It pretty much outlines everything you need to do to make the 52's work.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    it doesnt take a rocket scientist to figure it out. reverse the front mounts, the actual body mount portion of it is identical for either side. move the shackle bracket forward on the frame, 7.25" shackles are a good starting point. whats so hard about that? :confused:
  10. nomadman
    nomadman 1/2 ton status
    Oct 6, 2004
    168
    Enfield, Ct
    Is it possible to use stock bumper/brackets when moving the FT mount to the other side of the core support mount? Do you use a zero rate to put the axle back to OEM location or leave it 2" forward?
    The other thought I had was to leave both mounts in the stock location and use a zero rate to move the axle forward 1.5" and still use extended length shackles. Why move both mounts forward and the move the axle back, is there something I'm missing? Just move the axle forward if using a zero rate anyways.
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    this is true. I am in the process right now and am taking tons of pics for an eventual and thorough write up. Ive heard so many conflicting comments about this swap I almost feel duty bound to do it myself and report everything I can about it.
    j
  12. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    gotta go 56's :D i am going with a 1410 shaft anways, might as well make the most of it!:hack:
  13. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    52" spring swap article idea
    I think that the process to swap in 52" springs would make a wonderful tech article for everyone. Then we could direct most questions to the tech article.
