can u use a gen2 adapter plate on a gen1 kit
Discussion in 'OffRoad Design' started by b4w buggy, Jan 23, 2002.
  1. b4w buggy
    b4w buggy Newbie
    Jan 23, 2002
    md
    can i use a gen2 adapter plate on my gen1 kit? is it alum. or steel? do you still need to fab. a front crossmember to clear the front driveshaft on the new kit?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Generally the parts are not interchangable between the GEN1 and Gen2. the problem you run into is the shafts lengths are totally different since the adapter ends up so much shorter on the gen2. With the gen2 you still have to build a loop in the front crossmember and the adapter housing is steel.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
