can ujoint vibrate without looking bad?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Oct 28, 2001.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    I get a bad vibration under acceleration, goes away when I let off, but the rear u joint looks OK. No lift in the rear, just an add a leaf in the front. 33 inch Wild Country mud radials, 76 3/4 ton axles under my 87. Its stock otherwise.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  2. I have had a u-joint go bad, but every time I looked at it I thought it was fine. It was because the damn thing had tension on it and you couldn't see how bad it was. Block your tires and put it in neutral so you can move the driveshaft whiole watching it. I hope this helps.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>I Like my Burb'n on the ROCKS !!
    <font color=black>Imported to Kentucky through military channels !!
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Also a lot of times you need to take out the driveshaft to really tell if a jt is bad. Like was said... most times with tension on it it looks fine.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I had a bad u-joint that looked fine with pressure on it. I took the shaft out and found out it had alot of slop in it.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    I'll try doing that this afternoon.
    Karl
    87 3/4 ton
  6. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    Well, I replaced the ujoint this afternoon. The old one was only getting grease on two ends, the other two were dry. Took it out for a drive and it still vibrates under acceleration. Could it be in the tranny or transfer case? Or maybe a motor mount?
    Karl
    87 3/4 ton
  7. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    The tranny mount could be bad as well as the front u joint on your rear shaft. Have you had your driveshaft balanced? Also check your pinion yoke for play, could have backed off or your pinion bearing is nfg.
    Shawnboy.
    If you are having too much fun it's probably illegal.
  8. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Can a bad motor mount cause vibration in the rear?
  9. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Vibration under acceleration would indicate that the pinion angle is a little off, or your tranny/t-case/motor mount(s) could be bad. The pinion rotates up on acceleration, and the angle can be compounded when mounts start to sag. If your u-joints haven't been touched in over two years, I would replace (all) of them regardless. I would also look very close at the motor and tranny/t-case mounts for excessive "squishing". Get the poly replacement mounts and then you never (or at least for a very long time) have to worry about them. JMHO.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  10. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I had one that looked fine, and felt fine turn into this: pugsley.alloffroad.com
