Can Vortec heads work with 350 tbi?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Oct 12, 2000.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I'm having a hard time choosing an engine, these are my issues:
    1.I have a 1990 350 tbi, Id like to use my stock accessories including my TBI unit.
    2. I want more power for towing.
    3. Smog legal
    4. MUST run on regular unleaded.(I drive in Baja alot)
    5. Under 3 grand.
    Im considering a GM perormance engine, building my own, or dressing up a GM goodwrench engine. What are my options for combining tbi to one of these engines? Can tbi work with vortec or alum heads?
    thanks.
  2. On the Vortech head question you can run an edlebrock performer intake with the vortech bolt patern and run an adapter to use the tbi.Another option is to get some dart s/r's these are good heads and you can use your stock intake.You can also buy some alum heads,the best thing about
    them is that you can run a little higher compression on the same gas.The Vortech's are good heads,but in your case there
    is a little more adapting involved.The main reason people run the Vortech heads is that their cheeper,but with all the adapting involved in your case you mite be money ahead to go with an atermarket head that will let you use your stock equipment.
    Good luck
    IF IT AINT BIG IT AINT BAD!!!!!!
  3. 87Blzr
    87Blzr 1/2 ton status
    May 24, 2000
    111
    I'm not sure I understand why the Vortec heads are so unadaptable to his tbi motor. A friend has these on a 383 and I believe they have the center two bolts straight like the 87 and up intakes. These heads were stock on the mid nineties trucks. The adapt problem I believe was more when you wanted to use a carb because at the time there wasn't anyone that made a carb intake with the proper bolt pattern. Now they make everything to do everything. Its been a while since I had to deal with the Vortec's so maybe I am missing something. What problems do you run into putting Vortec's on a 87 and up tbi motor? People do use them because they are cheap but they also flow better than the bowtie heads. They are great heads. Why so hard to adapt?
    87 K5 Siverado, 68 SS 396 Camaro
  4. 87Blzr
    May 24, 2000
    111
    BTW I have noticed lately they also offer the Vortec's in the old style bolt pattern so you can use the old intakes on them. That won't help in his case but its now possible to bolt any intake to these heads now
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    87Blzr, the Vortec heads use an intake bolt pattern that is completely different than any previous SBC. There are only 8 bolts (four on each side, 2 at each end), and they all go in straight up and down. I keep hearing rumors that GM Performance is coming out with a TBI intake for the Vortec heads, but I haven't seen one yet. You would think it would be a good seller, since so many of the current crate engines are using these heads, and a lot of people want to put the crate motors in TBI trucks.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  6. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    The drilled and tapped heads were designed for bracket racers. Jim Pace and Scoggin-Dickey Parts Center does not recommend them for street use. Edelbrock makes a manifold for Vortec heads but it's a carb type. There are TBI's out there that can bolt on to a carb type manifold but since you already have it, I would opt for the World Casting S/R Torquer heads for cast iron or a set of Edelbrock Performer Aluminum heads.
  7. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
  8. 87Blzr
    May 24, 2000
    111
    Thanks for enlightening me. Blazer70, as soon as you mentioned only eight bolts it all came back to me. Thanks
