Can you "Burn rubber"?
Discussion in 'The Garage' started by SS66, Feb 22, 2004.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Can you \"Burn rubber\"?
    How many of you can spin your 42's or 44's on dry cement?
    If you can, post up your engine size and gear ratio /forums/images/graemlins/thumb.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Re: Can you \"Burn rubber\"?
    I can, But at the hefty cost of tires today I don't even think about it. Besides if I wanted to that I would build a Hot Rod.
    Bill
  3. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    I know I don't have 42-44s, but I can burn my 38's with 5.13s /forums/images/graemlins/peace.gif
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Only if I apply gas and a match /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/shame.gif
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i got 3.08 with 33's and a 700...helll no hahaha only on wet roads.. /forums/images/graemlins/rotfl.gif
  6. 85army tank
    85army tank 1/2 ton status
    Sep 25, 2002
    276
    southren mn
    /forums/images/graemlins/k5.gifI can hear the driveshafts and u joints now.wampa wampa wampa thump(duh). /forums/images/graemlins/k5.gif /forums/images/graemlins/histerical.gif
  7. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Thats exactly what I heard last time I tried to light up my 37's on a freshly paved street. I heard the motor screaming and when I dropped the clutch...BANG!!!completely gernaded my rear shaft...I haven't done it since...
    Chris
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The title reminds me of something a friend told me several years ago about his Chevy Citation company car. He said that the only way that car would "leave rubber" was if he tossed one out the window as he drove away. /forums/images/graemlins/wink.gif
  9. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    My old K10 would spin my 44's mercilessly. I could lay approximately 60' of marks at will, about that far out it was usually too far sideways to stay in it. /forums/images/graemlins/peace.gif I know this sounds like b/s bragging but TARussell, Ratzilla and maybe Rob85K5 can vouch for me. /forums/images/graemlins/grin.gif
    The motor was a roller 468, 5.13's and 44" TSL's.
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Nope. I run a welded 14bff, TPI350, 700R4, 4.56's and can't smoke 35's. I get mad axle wrap if it does try and spin and usually it just pushes my locked up front tires down the pavement.
    I stopped trying because I didn't feel like destroying my driveshaft. I found out yesterday that I had snapped a spring eye pin. Most likely from the added torque it has been seeing since the TPI conversion.
    If I took the top off and took all my spare parts, tire, toos, jack, etc out of the back of my truck I probably could. I still don't like the ideal of putting the strain on the driveshaft, 208, and 700R4.
  11. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I could smoke my 36" TSL's whenever my front tires had enough traction to overcome the rears with the detroit and 4.88's. Grooved tires wear down fast when you're showing off for hot chicks in a Camaro /forums/images/graemlins/dunno.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/whistling.gif
  12. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I have stock tires, stock ratio(guessing 3.08), 305, TH350 and I can't. I really want to but just can't. Hoping to change gears this spring.
  13. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Yep, I can do that but the driveshafts get $$$$$. /forums/images/graemlins/rotfl.gif
    427TD,4.56,44"
  14. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Heading uphill from a stop with the wheels turned....I can sometimes spin mine. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/whistling.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I could with my auto when a brake torqued with 35s and 4.10s and a gov loc.
    Only time I can light up the 38.5x16s is if it's raining and I get a little bit crazy with throttle. Scares the [darn] out of you too because you never expect tires that big to spin.
  16. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I can. I have a 350, 4.10s and 42s.
  17. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    the old 396 would easily burn the 38's, the 454 did a bit and in my 83 blazer the 350 does a fine job on the 33's...it's even better with granny gear /forums/images/graemlins/peace.gif /forums/images/graemlins/eek.gif
    trying to see how long it takes to kill the 10 bolt /forums/images/graemlins/whistling.gif
  18. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    AND WHAT EXACTLY WOULD BE THE POINT OF DOING THIS ???
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If ya take it easy on the 83 you could have something to drive all the time. With normal driving I chucked my ten bolt in 3 years /forums/images/graemlins/thumb.gif
  20. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    this is probably a stupid question, lol
    but how do you do this in an automatic?
    rev the engine in Neutral then put it in drive?
    or just step on the gas really fast
