Can you custom make tapered zero rates?
Discussion in 'OffRoad Design' started by BlueBlazer, Apr 4, 2002.
  1. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I did a search on this and couldnt come up with anything on here or on your site. I need a pair of zero rate add a leaves, but I also need to shim my pinion down 8 degrees due to a shacle flip. My question is could you take a zero rate and machine a taper into it? How much would it cost if you could? I found a guy who will do this for about 60 bucks plus Id have to get new center pins. If you could do better than this Id definitely go with you over him. I think this is something that a lot of people might be interested in so they can eliminate shims that are just sandwiched in between the pad and leaf, and at the same time get a 1" lift. Thanks in advance
  2. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Me too...
    Jim
  3. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Stephen,
    That sure would be nice. You probably have about thousand irons in the fire but, that would compliment the shackle flip quite nicely.
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Tyler,
    When Todds Pop was working at the Machine shop, he made several pairs. Pop said its fairly easy.
    These are very cool.
  5. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I would be interested also!!
    Mike
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I remember him saying something about he has done them, but doesn't do them very often because he has to set up the machines for the taper, and then has to reset them to the normal blocks which he said was a PITA if i remember right. If there was enough interest you never know though.
    I'm interested too. /forums/images/icons/smile.gif
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    im a machinist and it wouldnt be that hard at all , justtime consuming cuz steel is a pain to machine
  8. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    If Stephen doesn't do this I know a place that will make degreed shims. I had some made with a 3/8" lift that I welded to my Zero rates.
  10. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    They're all pretty much right on, we have done a few and at this point aren't set up to do them in big numbers.
    I should actually say that I don't know what it would cost for us to do custom tapers since it really comes down to shop time. We are short of machine capacity right now but that shouldn't be a permanent problem.
    One thing that we do is put a little flat on them for the head of the center pin to sit on so it's not side loaded, usually extra little touches like that cost a bit more. I'd have to think about it a bit to see if we could do it with the offsets and still make them work with multiple modes. I know you can't turn them around so that rules one mode out.
    Give us a couple weeks to dig the machine out from under the chip pile and we'll see what we can do.
  11. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Yeah, I had the bolt holes counter sunk and leveled to where the shims work on the bottom of the zero-rate. Real clean but they ran about $40 I think. Good info for you if you start producing them on a custom fit-to-app basis.
    Can we officially name zero-rate-add-a-leaf to ZRAL or something else easy.. /forums/images/icons/smile.gif
  12. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Most of us are just calling them 0-rates. Easy enuff.
  13. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    The term Pop used was "spot faced". As Stephen said, this step must be done to allow the center bolt to sit squarely on the O-rate....when cut at an angle.
    When Pop fabbed my 1" thick O-rates, we calculated that I needed 3.5 deg of taper. That doesn't seem like much but the center bolt will not sit squarely if you don't spot face. Aluminum degree shims just downright suck- this is the way to go.
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    I did this one time by taking a 2" lift block and cutting it in half at an angle with a box saw. Both blocks were then 1" high in the center, but tapered. Then a little work with a drill let the center bolt go through at the right angle and a litle grinding near the lower opening of the hole allowed the head of the center bolt to rest at the right angle. Then a longer centering bolt went through the tapered block and the spring leafs, tying it all together.
    You could also just take a regular lift block and have a maching shop mill an angle onto it and machine the surface for the head of the bolt.
