can you do this?
Discussion in 'The Garage' started by Jishory, Aug 25, 2006.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    find a high pinion dana 60 differential, match my rear 4.56 gears and take my 60 off and press out the center section and replace it with the high pinion center section, then i would have a passenger side diff thats high pinion. would it work or turn backwards?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    But where would you mount the springs? The spring pad would be on the wrong side of the center section.
    It'd be easier to buy a driver's drop t-case. Or buy a custom high pinion axle. Cheaper to do the first.
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    If your re-tubing it anyway, you make the tube long enough to mount a perch and it would just move your center over a little and I dont think you would have any problems
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i have one of those
    boyce built it
