Can you do this?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shawnboy, Jan 5, 2002.
  1. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Can you put locking hubs on an IFS vehicle?
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I don't think so...most are central axle disconnect. Even our Jeep with central axle disconnect doesn't look like you can put locking hubs on it. I might be wrong...but I've never seen a IFS Chevy with locking hubs.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. shawnboy
    Jun 22, 2001
    468
    Any technical if this is doable.
    Shawnboy.
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Not meant to sound like I'm knocking the idea, I'm just curious; Why would you want to? To permanantly lock the axles and keep the hubs manually controlled?
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Prior signature burnt. This one on temporarily.
  6. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Like Rene said, the front ends are centrally engaged. The best you can do is get a manual engagement cable to replace the electronic garbage for the front end. The front ends are set up similar to a front wheel drive car as you prob know. The axle shafts slide into the wheel hub and are bolted in. I have never seen and way to put a manual locking hub in nore do I see anyway it would be possible. You would never have to worry about the axle to wheel intergration failing usually unless the wheel falls off type thing..........The cable kits though can be reassuring. Check it out...<a target="_blank" href=http://www.jcwhitney.com/productnoitem.jhtml?CATID=37509&amp;BQ=jcw2&amp;_requestid=142854>http://www.jcwhitney.com/productnoitem.jhtml?CATID=37509&amp;BQ=jcw2&amp;_requestid=142854</a>
    Mike
    The jeep eater ......[​IMG]
  7. mpascino
    Jan 1, 2001
    557
    Connecticut
    Like Rene said, the front ends are centrally engaged. The best you can do is get a manual engagement cable to replace the electronic garbage for the front end. The front ends are set up similar to a front wheel drive car as you prob know. The axle shafts slide into the wheel hub and are bolted in. I have never seen any way to put a manual locking hub in nore do I see anyway it would be possible. You would never have to worry about the axle to wheel intergration failing usually, unless the wheel falls off type thing..........The cable kits though can be reassuring. Check it out...<a target="_blank" href=http://www.jcwhitney.com/productnoitem.jhtml?CATID=37509&amp;BQ=jcw2&amp;_requestid=142854>http://www.jcwhitney.com/productnoitem.jhtml?CATID=37509&amp;BQ=jcw2&amp;_requestid=142854</a>
    Mike
