can you figure this out..tranny or t-case problems...or rear end?????
Discussion in 'The Garage' started by supersize75, Nov 7, 2003.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    OK so this week my truck starts sliding on turns and chirping the tires rear bad and clunks a few times around corners bad.
    I pulled the diff and took out the carrier, there was alot of metal shavings but no chewed up gears like I was exspecting.
    The drive shaft will spin and then vilently catch after a few tries to get it in gear. /forums/images/graemlins/eek.gif
    I put it in four high and the front ha no problems..other than the cv hitting the crossmember, but thats anther project for some other day /forums/images/graemlins/tongue.gif
    So my thoughts are that..
    my tranny is ok, because all is well in 4wd with the front
    the t-casse may be going bad?? 203
    or the gove lock is the culprit?
    But would the gov lock allow the drive shaft spinning then catching?
    I am so confused here, looks like a detroit and open carrier at the end of the month and a new tranny while I am at it /forums/images/graemlins/eek.gif
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Sounds like a bearing or the gov lok with the metal shavings
  3. supersize75
    Sep 27, 2002
    2,638
    How about the pinion bearing..and the gove lock,
    could the gov lock going out cause the pinion bearing to go too, after talking with another member I feel that may be the problem.
  4. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Sounds like the Gov is about to puke /forums/images/graemlins/crazy.gif
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yup. Sounds like a guv lok about to go Boom!
    "And another one bites the dust"
  6. supersize75
    Sep 27, 2002
    2,638
    So this would still allow the slop in the drive shaft?
    spin then catch? /forums/images/graemlins/1zhelp.gif
  7. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Yup thats exactlly what it is, Gov-Lock go boom!
    Exact same thing happend to me last year. It felt like the rear end would launch off the ground when it hit. I finally dropped my rear shaft and drove in 4 high for about 3 months till I could afford to get the rear end fixed. It's funny without the driveshaft in place it never once made a noise or locked up.
  8. supersize75
    Sep 27, 2002
    2,638
    thanks, were your gears ok, so just a gov slop /forums/images/graemlins/grin.gif
    ALright, I'll go order a new one from the dealer for 729.63
    /forums/images/graemlins/rotfl.gif..detroit here I come..and I aint looking back. /forums/images/graemlins/cool.gif
