Can you get degree shims more than 6 degrees? And if so, then where?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Dec 1, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    All I've found so far is a 6 degree shim and I think I need 8 or 10 degree shims for my back axle. Will they have to be custom made or does somebody make them?
  2. 76k5Blazer
    76k5Blazer 1/2 ton status
    Sep 25, 2002
    176
    tracy ca
    I would just weld on new spring perches and correct the angle that way is its out that far
    But thats just me /forums/images/graemlins/k5.gif
  3. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Tyler, Try clicking on the A-Tron banner above. We just made a 8 degree for a fellow member. We will be glad to do it your way.
  4. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
  5. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Thanks for the link. Those 12 degrees look so tempting /forums/images/graemlins/smile.gif I guess I'll have to go get an angle gauge now. I've got 8" lift springs, I saw on the High Angle Drivelines product review that they had the Zero Rates tapered to 6 degrees. Is it safe to assume that with my 8" lift, I will need 8 degrees or more? My t-case has been lowered 1" as well. Thanks
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    IIRC, 6* is the last "safe" shim. going over that , things get squirlelly (sp?)
    I would have them rewelded. One less variable. Are you running a CV shaft? plan to?
  7. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Yep, I ordered a CV shaft, just figurin out what I'm gonna do to stop the vibrations. I've got 4 degree shims on there now, but I don't think that's gonna be enough.
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I am running 9" of lift (4" bds springs, 4" ord shackle flip, and the offsetting block) in the back of my K5. I have the high angle 1350 cv with a 241 sye. I also have a 14 bolt FF moved 1.5" back using an offsetting block I made. I am running 6 degree shims in the back of mine with no vibrations. The best thing to do is buy the angle guage and measure. Guessing may just cost you more money. I thought I would need the 8 or 10 degree shims, but after doing the measurements, I found that I only needed 6.
    I have a set of steel 8 degree shims I bought from the link above. These are brand new and never installed. If you think you can use them, let me know maybe we can do a little discounting on the parts I am buying from you.
    Here is another link that sells steel shims.
