Can you have an electric/manual tailgate crank?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nitrodrip350, Apr 29, 2003.
  1. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    I was reading either LMC or Chevy Duty and I saw a part listing for the rear tailgate with electric and a manual crank as well? Is this interchangeable with the strictly electric one? Or am I just completely reading this wrong? I want to change out to a manual since my damn motors keep burning out. I tried searching Chevy Duty but it's either too many results or none! /forums/images/graemlins/rotfl.gif
    Shane -
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I've never heard of a tailgate being both electric and manual, sure you were reading the LMC catalog correctly?
    But to answer your question, yes i believe you can change out your electic stuff for manual stuff /forums/images/graemlins/thumb.gif
  3. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    try running some thicker gauge wire tat way your not starving the motor for power which is what helps accelerate the wear on the motor.
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    You can definitly go from electric to manual. I did it, I got everything from my local GM dealer for the same prices LMC and chevyduty and all the others but with out the shipping costs. Just go there get a regulator, handle, lock cylinder, lock paul, E-clip, lock spring, new gasket for outside handle, and you're in business.
    Ben 87 Jimmy + 89 Blazer
    /forums/images/graemlins/usaflag.gif
  5. Nitrodrip350
    Jul 22, 2001
    358
    Centennial, CO
    How much was the total cost to do this?
    Shane -
  6. Nitrodrip350
    Jul 22, 2001
    358
    Centennial, CO
    So is that the wire from the loom to the motor? Or do I have to get a larger wire all the way back?
    Shane -
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    After experiencing my pops 77 blazer snapping off 2 handles for the rear window I switched my 79 to electric. My only problem is the cable I got from the salvage yard is toast. Both the motor and the window tranny work well. I have yet to see an aftermarket place sell this cable, would the dealership have one or is there a better route?
    sorry for the hijack but i can tell ya from personal experience the manual and electric window are swappable and direct bolt in.
  8. LIFSVR7
    LIFSVR7 Registered Member
    Jan 16, 2003
    51
    NW Indiana
    yeah, I know my manual is screwed up, I just bought all the stuff for the handle and locking, but the regulator skipped or something so it is uneven about a toothy.. I want to go power badly... /forums/images/graemlins/angryfire.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif what is all needed for power???
  9. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    It cost me 200 bucks all new from my GM dealer. As for people breaking the handles off, that to me is from lack of maintenece and being too rough with the handles. If you grease them when you first put it together, then maybe clean it and re-grease it every 5 years or so, I bet you'll never break one like so many have. It was totally worth it in my book, The window will always go down WHEN you want it to no matter how cold it is out or how low your battery is.
  10. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    not technically hijacking.... but, i have a oppositional problem to the above post. my rear window literally flies down, but refuses to go back up unless i am forcing it by hand to raise. is that likely a transmission problem or where should i start?
  11. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    The transmission has a built in spring that prevents the glass from flying down and assists you while putting it up, Sounds like yours is broken. I'm not sure if the spring is a replaceable part or if you have to buy the whole regulator. But it sounds like you need a spring.
