can you have too big of a tranny cooler?
Discussion in 'The Garage' started by SCOOBYDANNN, Nov 29, 2003.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I have 2 options to cool my 400
    1. Get a regular plain jane big cooler
    a) i like this idea but it puts another thing in front of my rad and i still havn't figured out my cooling problem.
    b. its cheap
    2. use my roommates super bada$$ big cooler w/ integrated electric fan
    a. i like this idea cause well its bada$$ and i know it will do its givin job
    b. i don't have to mount it in front of the rad.
    c. its basically free
    d. said roomate is know to be a crybaby later on down the road---he likes to refer favors.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    yes you can...
    1:figure out cooling problem
    2:buy plane jane cooler for trans and put it in front of rad, or under vehicle, but up out of the way enough where it wont get dragged over rocks..and is easy to hose dirt and mud, etc out of..
  3. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I talked with the guy from 700r4.com. He said that no matter which type of external cooler you use you should still run the trans fluid through the stock rad in conjunction with the external cooler. This provides some temperature stability and longevity to your trans.
  4. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    There is a problem w/ that---i had a standard tranny stock and don't have a factory tranny cooler inside the rad.
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] Better get a different radiator.
  6. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    im on a tight budget right now, but that is an option
  7. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    So run some of the tubing from the tranny around one of the radiator hoses. Make sure you don't restrict the flow. The direct contact will use conduction to transfer some heat.
    Also there are some problems in the great white north with tranny coolers freezing up. Make sure yours doesn't do that.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] I think the gains from that would be minable. You need water to come in contact with the tubing not a rubber hose.
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Given your situation I would run just the big one with the fan...just make sure you hook up the fan to either a automatic temp switch (I bet one for a radiator would work fine) or a gage and only turn the fan on when it is needed.
  10. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I dont know about big but I know a blazer running three coolers /forums/images/graemlins/deal.gif
    If I remember right it goes to a front cooler, factory cooler, then another aftermarket cooler.
    Only thing I see maybe the tranny pump handling the extra pressure/volume? /forums/images/graemlins/thinking.gif
  11. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Get a large cooler, and throw a t-stat on it so that it doesn't get any flow until the fluid has warmed up.
  12. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i thought that all of the radiators had an internal tranny cooler in them, but the radiators in the standard tranny trucks had screw in plugs in the holes for the cooler. /forums/images/graemlins/thinking.gif
  13. Grim-Reaper
    7,385
    Atlanta
    Never hurts to have more cooling potential then you need. The goal is to maintain about 180f of temp. That's just hot enough to cause and mosture in the fluid to become vapor but not hot enough to burn the fluid or harden the seals. There are Thermostatic Bypass's available that will passively maintain 180. I just block off the airflow to the AUX cooler in the winter with a peice of cardboard and watch the tranny temp gage.
  14. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I ran the 11" x 11" stacked plate cooler I got from afcoracing.com in series with the stock radiator cooler. It gets the hot fluid first, then on to the stock cooler. That way I know that the fluid is cooled, and I know that the fluid reaches the all important minimum temp to boil out any condensation. Plumbing it this way IS harder on the fluid though. Service the trans more frequently if you go this way.
    I also put a 265* temp switch in the trans pan that turns on a warning light, just in case. The switch is an over the counter VDO part.
    Most of the oil t-stats by-pass a little oil thru the cooler so that an air bubble can''t form there. Not sure if this is an issue or not. Does have the potential to delay the tran's reaching operating temp. You can find the t-stats on BAT's page. Baker's page, and CB Performance's page to name a few.
