can you make it work?
Discussion in 'The Garage' started by chris walker, Jan 30, 2007.
  1. chris walker
    chris walker Registered Member
    Sep 5, 2005
    42
    Arizona
    is it possible to put a tru-trac from a 9.50" rear axle in a 9.25" front axle if it is what would you have to do to make it work?
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    are you talking about an ifs front or one of the new dodge front axles?
    I dont think it would work either way. the ring gears are different sizes.
  3. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    And that could cause some issues...
  4. chris walker
    Sep 5, 2005
    42
    Arizona
    they both share the same internals the dodge and chevy their the same axle I dont know how much difference is in the 9.25 ring gear it shares the internal parts with the 9.50 so do you think it is the same carrier just with a slightly thinner mounting flange or what could be the differances between the two other than being HP vs LP
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The ring gear will not bolt on. Internals may be the same but the carrier itself is not.
  6. chris walker
    Sep 5, 2005
    42
    Arizona
    could it be made to work or should I just wait till they make one for it
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Not possible to make it work.
  8. chris walker
    Sep 5, 2005
    42
    Arizona
    alrighty thank you!
