Can you name this cross member?
Discussion in 'The Garage' started by chvyhs, Mar 27, 2004.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    This is the cross member I'm using under my Doubler adapter. The holes line up real well. I need to know which mount to buy.
    Here's the big pics:
    Fullsize pics
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Looks like a 203 crossmember to me...I don't have a doubler, but i believe the 203 crossmember is what you need.
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Looks like the one on my 84K10 with 700R4/NP208 and no skidplate.
    There are two pieces of rubber that go underneath that are rectangular and two pieces shaped like a "C" that straddle the crossmember on top. Somewhere I have pictures but I can't seem to find them.
    Anyway, the holes in it look like mine.
    EDIT:
    Found them.
  4. chvyhs
    Feb 12, 2001
    1,469
    I thought the cross member is out from under a 203 or 208. I can't remember. I did have one piece of a rectangular mount and I do have the rectangular skid plate.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    There is no such thing as a specific crossmember for each t-case. They are separated by the years.
    Up to '84 are all "flat" crossmembers like the pictures show. But the '81 to '84 crossmembers are flat and look a little different than the '80 and older members. Either will work as both are flat. The 203, 205 and 208 t-cases were all employed on these flat crossmembers. All will interchange with the other.
    The '85 and newer crossmembers are a different design. They look like "double humps". You cannot use an '84 or older t-case adaptor on the '85 and newer crossmember.
    1 ton crossmembers up to '84 are flat but different as they are shorter in heigth to compensate for the frame height. Again, the 1 ton members will not work because they will put your t-case up higher if you use one on anything other than a K30/3500.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    All figure 8 pattern trucks use the same crossmember and trans mounts.
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I just bought mounts for my X-member just like that. I told them it was for an 82 K5 with a TH350. You need two uppers and two lowers. About $25 at Autozone. /forums/images/graemlins/peace.gif
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Copy and paste from my post on the post-your-part-numbers thread:
    Tranny/case mounts @ Autozone 2 pieces: #2107 and #2108. You need 2 of each, 1 set for each side of crossmember. Made all the difference after swapping out oil soaked spongy original mounts. These are for 700r4 and np 208 combo 82-85. May fit other trucks.
    /forums/images/graemlins/thumb.gif
  9. chvyhs
    Feb 12, 2001
    1,469
    I'm running poly engine and tranny mounts. I want poly for this mount too. Does anyone have the number for the poly mounts?
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Right off of Energy Suspensions site Click me for list of Poly Bushings I run their greasable swaybar bushings and they work well. I ran their bushings on stock springs for 2 years and they still look good (in my yard). I run Autozone rubber on trans mounts as that what my motor mounts are.
    1985-00
    Transmission Mount (V8- automatic transmission)
    3.1129
    1968-84
    K10, K20, K30 Transmission Mounts (2 per set)
    3.1106
    1983-00
    Motor & Transmssion Mount Set, includes 2 motor mounts & one transmission mount (V8 w/automatic transmission only)
    3.1131
    1960-75
    K10, K20, K30 Transfer Case Torque Arm Mount
    3.1107 <font color="red"> </font>
