can you put an output shaft from a th350 into a th400?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Jan 25, 2002.
    i know the 27 spline is a step down but it would give me more t-case options.
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
  1. come on trannie guys!
    </font color=blue>
  2. mnstr_fx
    mnstr_fx Registered Member
    Sep 13, 2001
    78
    IL
    The output "hubs" are different in a TH350 than in the TH400. The TH350 has a clutch hub at the end of the tranny where the output is while the TH400 has the planetaries at the output shaft end.
    76-82 Chevy Pickup / Blazer - K5-K10-K30
    90' TBI
    TH 400
    203 / 205 Doubler
    Dana 60, Corp 14 - 4.88'd - Detroit Locked
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    What t-case are you wanting to use? The folks at http://www.advanceadapters.com/acrobat/gm.pdf You'll need the Acrobat Reader to display it.
  4. advance adapters = $$$ just wondering if there was any interchangability between the 2 cases. a buddy of mine has a couple th400s that are 2wd and i have some th350s so just trying to be cheep.
    </font color=blue>
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    If ya wanna play, ya gotta pay. [​IMG] The 400 is way beefier than a 350. I'd be surprised if any of the hard parts are interchangeable between them. You could always sell the 350's to help offset the cost of the adapters. [​IMG]
  6. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    you can buy a necked down th400 shaft that will allow you to use th350 inputs on the Tcase. It used to cost about $150 a lot of years ago. Most good tranny shops should be able to help you with this. I ran mine (long story) for 12 years behind a 455 Buick and never broke the 27 spline shaft. Good luck.
    Mike
