Can you replace spindle bearings?
Discussion in 'The Garage' started by backyardbuilt, Jun 5, 2003.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    If so how. Thanks for any Info Ryan.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Spindle bearings? You mean the roller bearing inside of the front spindles? </font>
  3. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Sure you can replace them. I'm pretty sure the part number is SBK-1 for the D44, it includes the bearing plus the seals that go on the u-joint end of the stubshaft to seal the backside of the spindle. Costs about $8 IIRC. The roller bearing can be tapped out from the opposite end of the spindle, they can be a bitch but they will come out.</font>
  5. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Thanks I just didn't want to start pounding and be there for a week on something that didn't come out. A broken stub shaft killed my rollor bearings.
  6. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    you still dont have all those 10 bolts around do you? look at one of those&gt; call if you need some help. I'm sure Brett and Emerson would love to help! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gif
  7. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    a slide hammer with the hook on the end does a good job as well.
  8. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    they all went to the scrap yard, I just used the last spare spindle I had so I have 2 that need new roller bearings so before I need 1 I wanted to get them fixed.
  9. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> There is a tool that bike shops use, commonly called a "rocket tool", it's used to remove bearing races from head tubes. They work great for removing that bearing. If you have a bike shop local to you and you can't get the thing out, I'd suggest taking a drive down there to see if they'll pound it out. Probably won't charge you anything to do it, especially if you bring them a 6 pack. </font>
  10. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
  11. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    No wonder's the idiots on bicycles around here can't stay on the side of the road (they ride right down the damn middle), there to drunk to stay on the shoulder /forums/images/graemlins/smile.gif There must be alot of people replacing spindle bearings around here lately, especially since the weather has gotten warmer /forums/images/graemlins/rotfl.gif
    P.S. I have found using a solid piece of brass to knock them out (stuck through the other end) works well and doesn't hurt the spindle itself.
  12. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    the best thing i found for this is a 2 jaw puller. make it so the jaws face out, then put a small punch between the jaws laying on the face of the spindle so the bolt of the puller is pushing on the punch. this way the punch pushes against the jaws for a tighter grip at the same time it comes out. using this method i have always been able to get them out in 1 or 2 minutes each without the hassle of hammering.
  13. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Ryan,
    Call Ron Istas at Inland Truck Parts in KC. Look them up in the white pages or online. Ron will give you the best deal on seals and bearings for your D60, and will give you the right parts first! Go Spicer joints too! /forums/images/graemlins/thumb.gif
  14. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    bigblock44k5 I think thats the best Idea so far plus I have a puller to use. Thanks
    Mudzer I was gonna do that since I'm part of KC4WDA I get a discount on parts from him to.
  15. BIGRIG
    Feb 29, 2000
    488
    Independence, MO
    we know all about those pullers dont we! /forums/images/graemlins/ignore.gif
    in, out, ground down /forums/images/graemlins/thumb.gif
