can you run a NP205 upside down?
Discussion in 'The Garage' started by cybrfire, Mar 1, 2003.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Post title pretty much asks my question. I know lots of guys have clocked them to varying degrees. Obviously the breather tube and drain or whatever is on a 205 would have to be addressed. What about oiling?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Why take the chance when you can get a Ford t-case with the front output on the opposite side and not have to take a chance of screwing anything up as far as the oiling system goes?
    Seriously, I think if you turned a GM t-case upside down, you are gonna have oiling problems....the gears inside won't get their required amount of oiling to keep them cool and lubed.
    Find a Ford 205 and swap the input shaft from a GM into the Ford. /forums/images/graemlins/thumb.gif
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Did Ford make a 205 divorced case. I thought about the Ford option but didn't know if they did the divorced thing or not...
  4. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Yep. I see them on Ebay every now and again. I am getting one with my RC60 The joys of Iowa farm trucks.
    Edit: Not from the same truck. Ford ran them until 76, I think. A guy that works for me bought a bunch of old Furds last year. I get first shot at the parts. Too bad he won't sell me the 77 K30 he bought.
    /forums/images/graemlins/crewcab.gif /forums/images/graemlins/burb.gif
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, Fords ran divorced, or remotes, t-cases on their Highboy series trucks. These are the F250's. They ran from '67-'77. Divorced 205's and 203's were both available on the F250's while all the F150's ran married, or mated, t-cases.
    In '77 1/2, Ford was at the "changing" year where they changed the F250 t-cases to the married version, to match the F150's. The Highboy was no longer. These '77 1/2 up to '79 were classified the Lowboys.
    Divorced 205's are plentiful. Farm trucks are the most common sources to scrounge them from. /forums/images/graemlins/wink.gif
    Another helpful tip on the '77 and '77 1/2 Fords: the '77 and older trucks ran the FE engines...the 360, 390, 427, 428, etc. while the '77 1/2 changed over to the 351M, 400, etc. Two different engine classifications and yes, two different bellhousing classifications, too. Motor mounts are also different and neither size will swap directly into the other year unless you get or buy the steel mounts at the frame ends.
    Ford fawked up a lot of things over the years. Too many engine variations along with tranny bellhousings make Fords one of the tougher vehicles to maintain. They are also the worst headaches anyone could ever have when working on their electrical systems. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  6. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    I don't know, to me Triumphs & MGs are worse.
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Damn straight, lights by "Lucas the Prince of Darkness". /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Thanks K30guy, Now I know what year ford I'm looking for. 67-77 F250. That will cut the laying on the ground time quite a bit...
  9. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    77's had both. Early 77's were divorced...late 77's were married so make sure to keep that in mind.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, already stated above. /forums/images/graemlins/wink.gif
  11. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Yes the 205 can be run upside down with now problems. I have one that has been run for several years and was even used in TTC a few years ago and the guy won several events and came in 4th overall. I now have that set up
  12. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    One good think about Ford 205s is they used the same case and spline count on all their trannys,Autos and sticks. /forums/images/graemlins/thumb.gif
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    True that...true that!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/wink.gif
  14. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Re: Worst Electrical systems
    Y'all ain't seen nothing until you've worked on a '65 Abarth-Simca Corsa 2000 GT. Built by an Austrian, in Italy, starting with a French car, with electrical parts sourced from both Lucas AND Magnet Marelli......
    Phords are simple. GM's are just as simple, but a little different in philosophy.
  15. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    [/ QUOTE ] I'm not working on any thing I can't pronounce. [ QUOTE ]
    [/ QUOTE ] Sounds like your avrage Jeep. /forums/images/graemlins/rotfl.gif
  16. NoRulz
    NoRulz 1/2 ton status
    Feb 6, 2001
    388
    Mesa, AZ
    the years on the highboys are correct, but the earlier one's used a D24 t-case. They used these until the early 70s (71-73, somewhere in there I think they switched to the 205)
