Can you run w/o your front drive shaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Mar 5, 2001.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I need to get some front drive shaft work done and was wondering if you take it out, will it still drive ok...
    [​IMG] Keep your feet dry [​IMG]
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Oh yeah, its no problem. I had mine out for some time since the slip yoke was worn. It dont hurt anything when its off.
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    The only problem you might run into is fluid loss.
    Running without the shaft won't cause any problems, but if the fluid leaks out, that will.
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Next time give more detail and this will be easier. Your profile says you have a 79, which means it should have an NP203. If that has been converted to part time then drop the shaft and drive it like normal. If it is still full time you will need to be in HI LOC or all power will go to the yoke missing the shaft.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  5. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    ya...it's converted to part time 4 wheel drive
