Can you say "flat belly"
Discussion in 'The Garage' started by jk5blazer, Jan 30, 2007.
  1. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    Just got done with the clocking ring and flatbelly cross member. All I need to do is make the skid plate. It took awhile and wasn't as easy as I thought it was but all and all I'm pleased. The front drive shaft angle could be better but it will do.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    NICE!!!!!!!!!!!!!!!!!!
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    :D It looks kinda like mine
  4. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    As soon as I figure out what the hell Im going to run for a T case I hope to have mine flat. The 208 has to go.
    Looks good!!!!:bow:
  5. jk5blazer
    Jan 28, 2005
    306
    Braselton, Ga
    Yeah mine will go as soon as I can get the 203/205 kit. I have both cases just not the important parts:D . Just thought I would make this work for now. $65.00 dollars and more time then expected, but worth it.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks great. i too have both cases, i just dont have the most important parts yet:doah: hopefully soon
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    What is that short adapter out of? I think it is the one I have in my K5 just not sure. If so I am already ahead just need the ring and fab up a crossmember:D. Oh yeah and cut a hole in the floor:D
    Ira
  8. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    the short adapter is from a 350-208. I got mine off Ebay for $20. I have all the parts laying around to do the clock and flat bottom. just ahve to find the time.
    could you take some pics of the angle on the front shaft? also how much clearance did you make for the case in the floor? how much body lift would it have taken to clear without cutting? the reason I ask is that I am going to clock mine. then take out as much bodylift height as I can. I have a 3" bodylift now. little more :hack: :grind: on the fenders and I will not need as much.
  9. sandawgk5
    Oct 28, 2003
    6,881
    HMMM, I have a 700-208 and I am pretty sure my adapter looks just like the short one. Atleast height wise.
    Ira
  10. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    ok, I don't know. I think its a year thing. my 83 had the taller adapter and the U shaped crossmember. my 85 blazer has the shorter adapter and the W crossmember. both trucks have 700's.:dunno: I plead the fifth since I'm drinking.:rolleyes: the blazer plow truck at work has the short adapter also and its and 81+. I give up.:crazy:
    I just know that I bought a short adapter and plan to flat bottom my truck even though I have never snagged my T-case on anything. prevention is a good enough reason for modification.
  11. sandawgk5
    Oct 28, 2003
    6,881
    Yesiree.
    My crossmember is that crazy double hump as if you cut the W one in half and flipped one side upside down. Almost like an S on its side like this ~
    Ira
  12. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    That looks really nice! Clocking mine is moving up on my list of things to do. Your just down the road from me. I'm over in Woodstock. Nice to see some some more Georgia people on here.
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    kick ass. A flat belly is definitely nice to have. I'm gonna get my 203/205 as flat as I can, and cover the skid with a sheet of UHMW. That oughta get me up'n'over.
    j
  14. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    The setup looks good. A couple things you should watch out for:
    The front driveshaft angle. Make sure you have plenty of down movement. I busted a High Angle Driveline 1350 from over-extending it with my Atlas, that is clocked flat.
    Another thing is to watch the body to transfercase interference. I thought I had plenty of room between my case and the floor. I had a good 1-1.5" clearence, but the first tree stump I jumped proved me wrong. The body came down on the case and stripped the 4 bolt holes that hold the adaptor to the tranny...
    Oh, and is it just the picture or is your tube crossmember flexing?
  15. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Very cool, I'll be doing the same thing after axles and suspension mods are done
  16. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    how is everyone liking there 241? anybody having any problems. mine is fixed but is anyone actually breaking them?
  17. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Flat belly pan is nice... and just like so many other improvements, once you get it and learn to drive w/ it - you wonder how you ever made it before doing the mod. Good job w/ those clocked t-cases...!
    Marv
  18. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    I have not broken one wheeling. I did break one flat towing the truck and having it jump into gear. A friend of mine broke one wheeling, his passenger thought he was helping out by shifting from 4-lo to 2-hi while they were still moving.:doah:
    If I break the one in my truck I will probably just replace it with another since you can get one in my area for $50-70, and I know everything will bolt right up. A doubler would be nice but then I would need new shafts, custom crossmembers, and it weighs a lot more.
  19. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    Clearance
    Looking good. What kind of clearance do you have between your front driveshaft and crossmember at full droop? I built an adapter plate to shift my crossmember back ~ 4" to avoid interference.
  20. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    My carrier bearing is mounted to the crossmember:D ... no interference.
