Can you shave a 10B...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Oct 7, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Just wondering if it can or should be done.
    thanks mike
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I would think that it shouldn't be done....those axles are weak already... /forums/images/graemlins/dunno.gif
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You could just smooth it out , and grind the lip of the cover so it sits above the bottom edge of the diff cover mounting area . Then it would just slide over stuff . I got hung up once with my 12 bolt pretty good , but never lost fluid because the cover couldn't get grabbed . But I wouldn't remove much of the housing , just smooth it /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks mike
  5. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i smoothed mine up so it wouldnt hang on the lip. ground it down the the edge of the cover and took off the squared off ears. i had to grind a little off the cover then causs it kept peeling back when i slid over rocks.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I smoothed out my 10 bolt front. Made it less grab prone and lost probably 1/8" or so. You could take more off if you felt like it but I like to error on the side of caution. I didn't want to end up like my 14bff did. I shaved it till I saw threads from the bottom bolt start to show threw. /forums/images/graemlins/doah.gif
    Harley
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I will smooth it out a bit. Thanks
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I've actually shaved them more since these pictures.
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Sure looks like a lot! I dont know they seam weak all ready. I think removing that much would be a bad idea. unless you are running small tiers i guess.
    mike
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, the existing "lip" I pretty much just radiused. What wasn't in the same radius as the overall radius I cut off (hence the lack of "ears"). I figure it can't be too much weaker than stock since I removed all the surface defects from the differential case.
    with 33" TSLs I have just over 10" of clearance.
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I am going to have 36" tiers. So i just might smooth it a bit.
    mike
