Can you swap an IFS 1/2 to 3/4 ton?
Discussion in '1936-Present Suburban' started by MilpitasK5, Dec 7, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    My buddy picked up a 98' burb with an 6 or 8 inch lift on 39s plus a 3 inch body lift. It's all pretty but everything is starting to break b/c he has a heavy foot!
    What can he do to beef it up? It's 1/2 ton.
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    the rear is easy get a 14bFF and put it under there the front is uncharted territory to me. what gears he runnin? he should use about 4.88s.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Switching the front to 8 lug would be a nightmare, you'd have to pull the entire crossmember out and switch them with a 3/4 ton truck...the best thing would be to switch it to a SFA front end, probably be cheaper anyway! If he can't do that, switch the rear end to a 6 lug 14 bolt, and that's about all you can do to IFS...
  4. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    PS...39's have NO business on IFS...my friends IFS burb with 33's constantly gets knocked off alignment.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The lift kit for a 1/2-ton IFS is different than the one for a 3/4-ton IFS, so swapping to the bigger IFS would indeed be a nightmare and probably cost a small fortune, especially after buying the correct lift kit for it. /forums/images/graemlins/frown.gif
    A Ford Dana 60 up front would have the diff on the correct side. Then a 14-bolt FF out back and some new 8-lug wheels would round out the package. Then he would have a VERY stout rig. /forums/images/graemlins/thumb.gif
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Off Road Unlimited has a conversion kit to remove the IFS crap and install a SFA. The kit is a little spendy though. /forums/images/graemlins/tongue.gif
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Regarding the option HarryH3 mentioned (swapping in a dana 60 - which is by far the best option) you may want to contact willyswanter (member here). This is his website: www.industrialoffroad.com
    (willys...hope you don't mind me linking your site/using your awesome crew cab as an example of how to do things right) /forums/images/graemlins/thumb.gif
  8. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    He busted his rear end already so he got it repaired and regeared for $1200 /forums/images/graemlins/eek.gif. He did that before talking to me about it b/c I told him he should have gotten a 14bFF. It would have been cheaper.
    I thought it would be pretty crazy to try to convert a 1/2 ton to 3/4 in and IFS. I just have no clue how those things work so I wanted to ask.
    I'll check out the link that you gave too. This will be fun to see which direction he decides to go in.
    Thanks,
  9. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Use a Chevy or Dodge front axle instead, and just use an additional divorced NP205 from an older Dodge. Dual t-cases - now that rocks /forums/images/graemlins/thumb.gif
