Can you use a trickle charger on a diesel?
Discussion in 'The Garage' started by Pookster, Feb 3, 2006.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    More specifically, can you use an automatic float charger (like a battery tender) on a GM Diesel, which has two batteries in parallel?
    I know there's something not quite kosher about it, but since the batteries are the same age/brand/type/capacity... I dont see a reason to say no right?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Not to sure, but I think It should work fine.
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I believe you'd just effectively have 1/2 the amperage to each battery.
  4. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    no problem...
    I've used one on mine before with no ill effects..I cant see how the charger would know if its charging 2 batteries in paralell,or one big 12V battery ..as long as neither battery has a dead cell or short,I see no problem using one..be aware a "tickle" charger will only maintain a battery,I've left mine on a dead one for days,and it barely cranked the engine over a few times..2 hours with my 10 amp charger,and it spun like a new battery..
    I had a charger off ot an electric warehouse "cart" that was 24V,similar to those used on a forklift..I simply hooked another 12V battery in series to the one I wanted to charge (after disconnecting it from the vehicle of course) and used that to charge my battery(s)..
    I think it worked better than my usual 10 amp 12V charger,it had the "pulse" charging in it,to "de-sulphate" the plates in the battery..I let a "freind" borrow it,and never saw it again..he claims he left it at the junkyard I worked at that closed a year ago..probably still there,locked inside the building..:doah: :mad:
  5. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Why not just get two?
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    cant use two, they are in parallel. There's no issues when they charge battery banks, so Im not real concerned about that- just double checking.
    You cant use two , because one charger would be confused by the presence of another charging source. It would certainly bounce around a lot.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Yes, it should be fine. The one charger will keep up both batteries. When they are wired in parrallel like in almost all diesel applications the batteries all work together to make up basically a much larger battery in a sence.
    You are just trying to charge a battery twice as large.:wink1:
    I prefer charging two batteries together, I think it's easier on the batteries when the power is split to both.
