can you use co2 to air up tires
Discussion in 'The Garage' started by big83chevy4x4, Jul 1, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i don't see why not, but im leaving in about an hour and want to know
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    That is what I use.. Never had a problem.. The only thing is if you use air tools with it.. Make sure you oil them up a lot.. Co2 has a lot of moisture..
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sweet, thanks ill grab the tank. /forums/images/graemlins/waytogo.gif
  4. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    That's what Powertank and Outback Air systems are.
    I plan on making my own.
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Make sure you grab a regulator to.. When I first did it.. I thought I could just crack it open a little. Nope that doesn't work.. Blew up three hoses on a trip to the con. One of them almost hit somebody when it blew..
  6. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    We use CO2 for airing up tires, operating an ARB Air Locker, Air Tools, and MIG Welding. By the way there is very little moisture (H2O) in CO2, less than 15 Parts Per Million in Industrial Grade CO2 which is 99.5% pure. You can also get Instrument Grade which is 99.98% pure. Liquid CO2 is heavier than water, so if there were any moisture in the tank it would rise to the surface and blow off first. The moisture that most people see when working with CO2 is condensation from the air. When CO2 is released from its pressurized liquid form as a gas there is a rapid temperature drop which condenses the moisture in the surrounding air. The moisture is not in the CO2.
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I stand corrected.. But it still collects the moisture inside the tools. I have seen it take out a couple of good quility rachets.. You need to oil them up often..
  8. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Your supposed to oil the tool every time before you use it.
  9. BAJA_BLAZER
    May 17, 2001
    517
    San Diego, CA
    If your compressor is anything like mine, it’s got more water in it than air. I know the fix, but it involves going outside the shop to the compressor closet and reaching down where the Black Widows live. Besides all the water blowing out of the air tools helps to keep me cool in the summer.
  10. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
