Can you use heads of a 6.2 to a 6.5L?
Discussion in '1982-Present GM Diesel' started by Klink K5, Mar 16, 2005.
  1. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    I have a 1996 k3500 6.5 engine that has cracked heads on it and I was wondering if I could use the heads off a 1984 ish 6.2 and have the same power. I have not reasearched this at all yet so I am looking for somevaluiable input. Thanks, Klink
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Iknow you can't get the same power since the heads are different.
    I know people do the opposite and bolt a 6.5 head on a 6.2 for more power, basically bigger valves and better flow design.
    Maybe someone who has tried this might chime in.
    :grin:
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I read a tech article on a site (Oliver performance maybe?) where they used 6.2 heads and basically made them into 6.5 heads through portwork, valvework and such. I think you can use them, but it would be a waste of time and money. Better to fix it right in my opinion. You'd feel sick to spend the money, get it all put together and be disappointed with the reduced power output.
  4. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,038
    1,106
    Dallas
    The heads do bolt up. One can put any prechamber desired into any 6.2 or 6.5 head. Aside from early 6.2L heads, all the valve sizes are the same. The cooling passages were upgraded for better flow with the 6.5L heads. Around '90 or so (I can't remember specifically) the injector angles went to a more vertical configuration. This is likely for extra clearance for an upcoming factory turbo package, but there haven't been any specific performance advantages attributed to this angle change.
    While the heads may make some slight difference, the best value for one's money during a full 6.2L rebuild, assuming one already has crack-free heads, is to rebuild the 6.2'ers on hand with turbo prechambers and short-body turbo injectors. That's where the real power comes from.
    Cracks between the valves seats are repairable. Your local machine shop should be familiar with the SAE repair procedure, and if not, I know there are several mail order places that will do an exchange with you. The Diesel Depot comes to mind.
