can you use the stock 2wd pitman arm for crossover
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, May 4, 2001.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    south central wa state
    the stock arm looks like it has a built it tie rod end. is this thing one piece or can i take it out? if it isnt salvagable, what type of arm do i use?(78-79 f150?)
  2. thatK30guy
    Jan 12, 2001
    I have seen the stock pitman arms to have the tie rod end "built" into it also. I have never seen a stock arm without the tie rod end. My answer would be to use the pitman arm from the 77-79 F150 like you said. Especially if you have a lift kit, get the drop pitman arm from any lift kit supplier. This will reduce the angle on the drag link.
