Cant believe this.....
Discussion in 'The Garage' started by Flexy K20, Jun 18, 2003.
  1. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Alright so I'm sitting at home tonight (2:30am) and I think maybe it's a good idea to add up the whole Dana 60/Corssover Steering project. This is everything I've done and what it cost:
    Complete 1979 Dana 60~~~~~~~~~~ $700
    Gear Install~~~~~~~~~~~~~~~~~~ $140
    Carrier (Ebay~~~~~~~~~~~~~~~~~ $50
    Randy's Ring & Pinion Seals~~~~~~~~ $50
    Sky Manuf. Crossover Arm~~~~~~~~~ $123
    Turn Dana 60 Rotors~~~~~~~~~~~~~ $30
    Sandblast Rotors~~~~~~~~~~~~~~~ $30
    Have Kingpins Removed~~~~~~~~~~~ $50
    Kingpin Rebuild Kits~~~~~~~~~~~~~~ $101
    35 Spline Outer Kit~~~~~~~~~~~~~~ $350
    Inner Non-Neckdown Shafts~~~~~~~~ $170
    Calipers~~~~~~~~~~~~~~~~~~~~~ $60
    Tie Rod Ends~~~~~~~~~~~~~~~~~~ $80
    2WD Steering Box~~~~~~~~~~~~~~ $30
    Superlift #1104 Pitman Arm~~~~~~~~ $50
    ORD Crossover Draglink~~~~~~~~~~ $105
    Thick Diff Cover~~~~~~~~~~~~~~~~ $20
    New bolts for everything~~~~~~~~~~ $10
    Free Stuff:
    Blast and paint Axle, Steering Knuckles, Diff Cover, Lower Steering Knuckle Plates, top kingpin cap, steering box, Weld gears
    PARTS TOTAL -------$ 2149 /forums/images/graemlins/angryfire.gif
    So.... I thought I got a good deal on the axle, and I guess it would have been a good deal execpt I decided to build it once and build it right. Hopefully I wont be breaking it anytime soon. Sorry I know this was kinda a pointless post but I just thought I would share, because I was bored. /forums/images/graemlins/1zhelp.gif Later
    -fLeXy K20
  2. 1972Blazer
    1972Blazer 1/2 ton status
    Jan 2, 2001
    238
    carlsbad, California 92009
    I am doing the prices for a build on a 14Bolt SF 6Lug rear axle. It is scary if you do it right, just a few hundred from a Dyna Trac axle that is all new, stronger and has a warranty to top it off. I am at $2000.00 between just parts and setting it up for my 1972. Then there is the initial cost of the axle between $550.00-$850.00 it is staggering!!!
  3. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I have learned to not add the stuff up. Its very amazing how much it all adds up.
    Ken H.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Well, if it makes you feel any better, here are some quotes I got for front 60's:
    Corby,
    Thanks for checking out the website, here's the information you requested. The Dana 60 front axle with disc brakes and a 4.88 ring & pinion from Precision Gear is $2350.00. The options you mentioned are a Detroit locker, add $500.00, a pair of Warn hubs, add $89.00, and the 1410 yoke, add $75.00. So your total would be $3014.00. U-joints are not normally supplied, they run $22.00 each. We appreciate your inquiry, please call to place your order.
    Performance Gear & Axle
    601-796-2026
    and
    DYNATRAC www.dynatrac.com
    PRODUCTS CO., INC. Effective: June 18, 2003
    7392 Count Circle · Huntington Beach, CA 92647-4551 · (714) 596-4461 · Fax (714) 596-4449
    68 Thru 91 GM Pickup & Blazer
    Pro 60 Hi-pinion Front Axle
    Part No. GM60-3002-A
    Axle Package
    Complete Dynatrac 60 axle assembly with 12 month limited warranty Included
    Axle is set-up for an application with a passenger side offset pumpkin Included
    Dynatrac Pro 60 Hi Pinion housing Included
    Includes Warn heavy duty manual locking hubs Included
    SD 35 Spline, 1.5” induction hardened alloy steel inner axle shafts (uses 1480 axle joint) Included
    HD disc brake assembly with a 6 on 5.5 bolt circle Included
    Choice of ring and pinion ratio (3.54:1-5.13:1) (5.38 available, call for pricing) Included
    Open differential Included
    Best pinion angle and wheel alignment for 4-6” lifts (max. warranted pinion angle - 11 degrees) Included
    D60 heavy-duty steel differential cover Included
    1310 U-bolt style yoke (U-bolts included, Other yokes available call for pricing) Included
    Dynatrac Pro 60 knuckle, Pro 60 wheel hub & spindle package Included
    High clearance u-bolt and spring plate kit (Subtract $159.00 to remove) Included
    Width 69.25” (Stock 67’ to 69.5’) Included
    Assembly is finely detailed with a hi-gloss black finish Included
    _______________________
    Total $4604.00
    Upgrades:
    ARB Air-Locker $ 639.00
    Stainless ARB Line $ 69.00
    Detroit Locker $ 425.00
    Powr-Lok $ 349.00
    Hi-Clear. Steering $ 695.00
    X-over Steering $ 595.00
    Stainless brake hoses $ 109.00
    35 sp Premium hub & outer shafts $ 298.00
    8 on 6.5 wheel bolt pattern (SRW) $ 0
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you don't even have a locker in there yet. a rebuilt D60 can easily get into the $3,000 range, so your doing pretty good.
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Thank you for posting this. Makes me feel a ton better for spending 3.5K on the whole truck!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    Nope Zakk no locker yet, thats why I welded the spiders /forums/images/graemlins/rotfl.gif I have a extra set of spiders in case I hate the steering. Yeah then in a month I am going to 4.88's and a locker (arb, or detroit). So yeah the list keeps on going.
    -fLeXy K20
  8. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Heres what I have in mine:
    +$1500 - 84 M1008 from Wes with 14B & Detroit and D60 w/4.56s
    -$725 - Sale of Remaining parts
    =$775
    +$450 - Ebay Detroit for the D60
    +$165 - ORD Arm
    +$175 - MOO Cover with Ram Mount
    +$4 - 2 Cans of Rustoleum - Didnt cost me $4500 either (DynaCrack)
    =1569 Total.
    And I hammer it everywhere I go. I dont believe in upgrade till I break something - meaning, Im not going 35 spline outers till I start breaking 30 spline outers. /forums/images/graemlins/grin.gif
  9. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    sure does make rockwells seem like a good deal... they dont really need much in the way of extra poop usually (35 spline kits, thick diff covers, new inner shafts etc etc) and over at POR ya see em for $1k for both the front and rear axles. I dont know how much my D60 cost me in the end... and quite frankly I dont wanna know. $2xxx.xx is close enough for me. /forums/images/graemlins/grin.gif
    j
  10. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Here is mine so far:
    D60 came with trac loc and 4.56's $1100
    arb $650
    5.13's & install kit $350
    labor of install for gears and arb $600 /forums/images/graemlins/angryfire.gif
    sky crossover arm $130 (i think)
    pitman arm (coming from thegeneral) $40
    ord bent draglink with end's (coming from thegeneral) $85
    hydro assist with ram, pump, box, hydroboost system with all of the lines (coming from thegeneral) $270
    35 spline outers (did not order yet)$350-400
    1410 yoke (did not order yet)$?
    tie rod end ( building my own sleeved ROD) $80+/-
    ***$3705***
    Did I miss anything? /forums/images/graemlins/thinking.gif
  11. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    heres my price list so far for the 1 tona xles
    -dana 60 and 14 bolt- 900
    -rebuilt with 4.56, detroit rear, powerlock front- 1100(including brake work)
    -selling old 4.10's and front carier- -250
    -dana 60 calipers- 110
    -crossover steering arm(jkw) 90
    -Modify curfent crossover draglink(shorten 3") 65
    -rancho dana 60 u bolt kit- 25
    -por 15 paint and supply- 55
    total 2095. not bad for front and rear axles.
  12. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    I'm glad my wife doesn't look at this stuff, she'd have a fit if she knew what it really costs. /forums/images/graemlins/eek.gif
