Can't decide on engine!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5Blazer, Dec 13, 2002.
  1. 90K5Blazer
    90K5Blazer Registered Member
    Jun 10, 2002
    48
    Dayton, Ohio
    Can\'t decide on engine!?
    My 90K5's 350 is starting to poop out on me. She's got 175,000 on her. Still runs good but starting to loose a little power and a burn a little oil. I am considering a 330HP 350 from Summit, but it says pre-1976 only. Will this cause me problems with my computer or anything else? What other engines would be worth looking into? I want a little more power than stock, but don't want to mess up the 700R4 tranny with too much power.
    Thanks-
    Mark
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Re: Can\'t decide on engine!?
    Your stock TBI system will adapt itself to some change in cubic inches and more power, but IMO 330 HP would be pushing it. You could buy a performance engine from several builders including GM that are designed to be used with your TBI system. OR you could but a higher perfomance engine and modify your TBI system with a custom chip, etc. But the cam has to be compatible with your FI system.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I don't think you'll be anywhere close to 330hp after bolting on TBI. I think you'd be better off with a mild 383 or 400.
  4. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Put a 2.2L V-tec motor in it. She'll do wheelies when your done! /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Nah, just put a type R sticker on it.
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Just get a stock 350 w/ vortec heads and FT pistons....the stock PROM should be able to cope and it will make a bit 'o power
    Chris
