Cant figure out my Blazer
Discussion in 'The Garage' started by tenderfoot1877, Dec 23, 2005.
  1. tenderfoot1877
    tenderfoot1877 Registered Member
    Apr 10, 2005
    13
    San Antonio
    for the last two months, my Blazer has been giving me problems. When I start it in the morning, it runs OK, but after it warms up, forget it. It runs like crap. After its warm, and I press the gas to either pass some one or to just accelorate, it bogs down almost as if it isn't getting enough gas. The injectors are fine, Ive changed out the PCV valve, the EGR valve, spark plugs, rotor, cap, fuel filter, gutted the Cad. converter cleaned the throttle body, and replaced the throttle possiton censor. I DONT KNOW WHAT ELSE TO DO. PLEASE HELP:confused:
  2. warreclipsegst
    warreclipsegst Registered Member
    Sep 26, 2005
    23
    Pennsylvania
    Check to make sure your choke isn't sticking closed..
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    My first guess would be a fuel issue as it warms up. As in its running lean and slowly overheating. Fuel filter, timing, fuel pump... ????
  4. tenderfoot1877
    Apr 10, 2005
    13
    San Antonio
    I don't know to much about Throttle Bodies, where is the choke on it?
  5. tenderfoot1877
    Apr 10, 2005
    13
    San Antonio
    maybe the fuel pump, but it gets plenty of fuel so I don't think so
  6. resurrected_jimmy
    May 23, 2005
    2,241
    I should pay attention to what I read. I doubt choke but its possible I guess. Since its TBI you really need to know the fuel pressure going to the injectors. My next guess would be o2 sensor or TPS (throttle position sensor), I had one behave like this because of the knock sensor.
    Is it not throwing any codes? Is your check engine light on?
  7. tenderfoot1877
    Apr 10, 2005
    13
    San Antonio
    my check engine light doesn't work and I just changed the TPS yesterday. I dont know how it would act if the o2 sensor went out so maybe
  8. warreclipsegst
    Sep 26, 2005
    23
    Pennsylvania
    sorry, didn't know it was TBI. forget the choke post
  9. resurrected_jimmy
    May 23, 2005
    2,241
    ok, we need to know if its throwing codes. Ummmm, can't help with the check engine light not working I hate dashboards, but if you can get a code reader to tell you if its giving a diagnostic code that would be worth its wieght in gold!!! I don't think you can read OBD I codes without a check engine light (correct me if I'm wrong)
  10. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i had a problem like that about a month ago , mine ended up being a small vacum leak & the ecm was about dead, it sure would be nice if you could check the codes. good luck!
  11. 88-383
    88-383 1/2 ton status
    Sep 11, 2005
    142
    Tracy. CA
    Just throwing out some thoughts. Bogs are usually fuel or timming related. So here's some things to think about.
    1) Vacum leaks can be a headache.....
    2) Does it bog in nuetral?
    3) How does it drive when cold? no bog at all?
    4) After the ecm goes closed loop @ 140-160deg the ecm makes decisions about mixture based off readings from the O2 sensor*** prior to going closed loop the ecm runs a warmup program/routine or profile etc...
    Engines that dont seem as crisp after going closed loop may be suffering from degraded O2 sensor performance. **I'm asuming we're talking about a totaly stock TBI truck here** headers,custom chips and other mods can also cause similar issues.
    The codes can be pulled even though the light doesn't work but you'll have to have a scanner that connects to the ALDL. I'm a TPI sort of guy thats new to TBI.
    Good Luck
    Kelvin
  12. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Throwing random parts at TBI does nothing but cost you money. If you are gonna spend money, I'd put that into a new lightbulb for your SES lamp, and check your codes :)
    Start simple, then go from there. Chances are your TPS was just fine as was, and probally set you back a good 40 - 50 bucks.
    Hows your timing look? My 89 was at about 14 degrees ATDC (I usually set mine about 5 degrees BTDC) and it was behaving much the same way. Started ok, but had absolutely no power, and would backfire through the throttle body etc. TBI has the ability to adjust the timing electronically, but it still needs the dizzy to be set accurately to be able to base the timing in the prom off something.
    Second, check your fuel pressue. If you've got no fuel, you've got no power.
    Then check your 02 sensor out. Take it to a local parts house, and have them put the OBDI scanner on. Usually they'll do it for free. Chances are the kid working there will have no idea what he is doing, so yeah, you'll be looking for the 02 sensor to be crossing between .2 and .8 volts on a consistant basis. If it ever sits still at a certain voltage for more than a second, or if it provides no voltage at all and runs the truck in open loop, then the 02 sensor needs replacement.
    Last things I'd check would be the MAP, injectors, then knock sensor, and very last would be the EST module, or ECM. ECMs don't just sorta half work, they either do or they don't like most electrical components, lol
  13. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    I just went through this. After replacing the O2, MAP, Electronic Spark Control and knock sensors, finally got around to the fuel filter. After over $150 in parts, a $2.99 piece fixed the problem. Haynes and Chiltons never mentioned it. Good luck.
