can't figure out problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Frank, Dec 20, 2001.
  1. Frank
    Frank Registered Member
    Oct 2, 2001
    16
    can\'t figure out problem
    Please help I can't figure out the Problem on my 1987 K-5 Blazer:
    When I step on the brakes, it pulls to the left.
    I replaced both brake calipers assembly with brand new ones . and it still pulls to the left.
    will appreciate anty tips, thanks!
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: can\'t figure out problem
    Is the rotor warped? Bleed the line and try it again. You could have an air hole in the line and drawing in air to that side.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    you may have a bad proportioning vavle also.
    good luck
    Go heavy or Go home[​IMG]
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    the proportioning valve only controlls front to back braking. have you tried new pads? i had the same prob. and did everything i could think of to fix it except taking to a priest. then i replaced the pads and holy cramp it's fix, i also had the rotors turned and that helped a little more
  5. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    If you have replaced both calipers and pads Check the rotor to see if it is out of round. Also check for worn suspension and steering components. Tie rods, shocks, ball joints etc..
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  6. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    I had the same problem, Although I screwed up and corrected 2 things at once so I don't know what fixed it.
    1st I had a cracked frame on the steering box, Weld on kit and brace.
    2nd I replaced the rotors, calipers and pads.
    My quess would be your rotor if you steering box is o.k.
    The Few, The Proud, The K5 Blazer
  7. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Do you have any lift on your truck?It could be bump steer caused by the front of your truck diving durring braking.
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  8. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I would suggest rotors are not right, meaning warped, grooved or something of the sort. You can warp rotors by not tightening your lugs correctly too. You need to do a cross tightening instead of going around the clock with them. Sounds silly, but true.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>BLAZER PICS</a>
  9. HuskerBlazer
    HuskerBlazer 1/2 ton status
    Mar 22, 2001
    119
    MI
    Watch out for a faulty brake line too...I had a kink or a bubble or something in my right side brake line. Wouldn't let the brake fully release, so when I braked, I got a pull to the right because basically all the pressure went to the one right side brake. Just something to look for if the rotors don't turn out to solve the problem.
    K-5...Soccer moms inquire within.
  10. Grim-Reaper
    7,385
    Atlanta
    If it's lifted then I would say it's lift related. Either its not got a steering correction on it or it's the sway bar binding when the nose comes down under braking.
    Welcome to CK5.
    Please fill in your bio and include some details of your truck.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  11. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    Sounds like a bad brake hoses to the calipers. Replace them both in pairs. They are cheap. Make sure you bleed the system good too. Also check for a worn ball joint, this will also cause the symptom you are having as well.
    T.J.
  12. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    I agree with replacing the hoses. my buddy's motorhome was having the same problem. we changed everything but the hoses and still had the problem. changed the hoses and the problem went away.
    start with the hoses. cheap and easy.
    harry
    69k5
  13. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Could also be as simple a s same air pressure in all tires
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    It's all fun and games till someone loses an eye!
  14. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I had this same thing happen to me a couple months ago. Looked at the pads and rotors, pads had nothing left and my rotors were glazed over. I would check them out.
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. 4.11s Locked front and back.
  15. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
