cant figure these hubs out
Discussion in 'The Garage' started by k5floyd, Nov 13, 2004.
  1. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    im replacing the auto hubs on my 88 and i started taking them off, but i cant figure out how to get the body of the hub out. it seems so simple but i cant figure it out. anyway, i need someone to tell me how these things come out.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    did you take out the allen head bolts?? /forums/images/graemlins/dunno.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what do you mean by hubs? The manual/auto hubs, or the rotor/hub assembly?
  4. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    There should be 2 snap rings - 1 on the end of the stub shaft and another in a groove in the end of the bearing hub "snout" (you'll probably need a pick for this one).
  5. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    yes i took the allen head bolts out. do i need to take the rotor/hub assembly off?
  6. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    [/ QUOTE ]I had the same problem with mine, the grease created a suction at the lock ring. I bought a set of picks and used the 90 deg pick to work them loose, I hope this helps you out. /forums/images/graemlins/eek.gif
  7. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    If you already have this one out then take two of the small allen head screws and put them in the end of the hub so you can use them as handles to pull the hub out.
  8. dremu
    Feb 27, 2000
    15,967
    458
    East of San Francisco
    Nope, you can remove the locking hubs (manual or auto) with the tires still on the ground.
    -- A
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The auto hubs have two little pieces sticking out you squeeze with pliers and they come out that way.
  10. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    yeah, like 10 min after my last post i figured them out. i was WAAAAAYYY over thinking them, too simple. haha, thanks guys
