cant figure what engine i have, what it came out of ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scrappyk5, May 6, 2002.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i looked all over the the mortec and nastyz28 , and i cannot
    find what my motor came out of , the number on the block is
    # 14102058 , which is a 305 from 87-92 .
    but when i looked for my suffix code which is # k0924fjh, i cant find it in any of the lists.
    i am pretty sure i am reading it correctly, and i really need to know what my motor came out of.
    any body have any ideas?
  2. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    well after a lot of looking around , it looks like the motor
    came from one of the following , 1987 c10,k10,c20. not
    sure which. the h/p is 170, and the tq is 260.
    now this gives me something to go by.
    i wonder how much the hp. and tq. has change
    when a quadra jet carb was put in place of the original tbi
  3. dyeager535
    26,981
    Changing from carb to TBI or vice versa is going to be misleading from a power standpoint, as the cam was installed by GM to work optimally with the installed components. (Heads, carb or TBI, intake, exhaust, valve size, chamber size, etc)
  4. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    Your casting number shows its a 87-88 305 block
    can't find TQ or HP levels because I think you dont hae the right numbers from the stamp on the front of the engine
    my book says that any "F" starting stamp was from 1955-1969
    if you come up with different numbers from the front of the block..let me know and I will try and help some more.
    thanks
    travis
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Pop off the valve cover and tell us what the head says. FJH indicates a 305 in K5 C10 K10 or C20. #14102058 is supposed to be an 87-91 roller cam 305 w/ one piece rear seal.
  6. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    i know , its got me confused too.
    i will pop the valve covers off this weekend
    when i replace the gaskets.
    thanks .
