cant get my driveshaft out...---got it out
Discussion in 'The Garage' started by TXsizeK5, Apr 9, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I finally get in my cv shaft but i cant get my old shaft out, the ujoint is stuck in the pinion yoke, ive tried hammering, kicking, pulling, pushing! What do I do?
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Re: cant get my driveshaft out...
    torch it or use a cut off wheel to cut the joint in half. that should free up enough area to break it loose.
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    stick a pry bar in there, if thaty don't work you got something rusted BAD all mine came right out /forums/images/graemlins/confused.gif
  4. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    GET A BIGGER HAMMER!!!! Simple rule of /forums/images/graemlins/thumb.gif that will do the job.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    should I be happy mine slides back and forth in the pinion yoke creating that nasty vibration?
  6. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Are you supposed to jack it up? or does it have any affect leaving it in gear or the tires on the ground?
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    its just rusted that bad? mine was stuck in because there was some bad grime buildup but it popped out easily compared to what your saying.
  8. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, first of all, set your parking brake or chock the tires because once you get the shaft free, there's nothing keeping your truck from rolling over you. /forums/images/graemlins/eek.gif
    You should just be able to bust it free...rust shouldn't have too hard of a hold on it. I'm sure you've tried everything you can think of, so it's not going to do any good if I rattle off various ideas, but just keep trying - sooner or later it has to bust free. /forums/images/graemlins/thumb.gif
  9. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    it shouldnt be rusted, i just got a new axle and new Ujoint....
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Did you remove the straps? /forums/images/graemlins/tongue.gif
    I would take a 1/2 extension and place it on the cap in the pinion, then smack it with the 2lb sledge. This could create enough lateral pressure to bust it loose. Then I would repeat the process on the other side to try and break it loose. The extension should focus the force directly on the ujoint itself. Then I would try a prybar in the gap between the joint and the pinion. If that doesn't work, get a propane torch and heat it and try the above process.
  11. heavy4x4
    Aug 28, 2002
    3,270
    That's right, didn't you have a shop put some new axles in for you? (If not, then I'm thinking of someone else, sorry) If that's the case, I'd call that shop and ask them what the he!! they did. /forums/images/graemlins/deal.gif
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Make sure that the brakes are set and that the tranny is in neutral. This will remove any bind from the driveshaft. It can be a real beotch to get the u-joint to pop loose if you just pulled up and dropped the tranny in park and then let the truck settle back against the park pawl. /forums/images/graemlins/shocked.gif Then, if it's still sticking, insert the end of a pry bar between the u-joint and the yoke and pry it outta there. Be ready to catch the driveshaft if it suddenly pops loose! /forums/images/graemlins/wink.gif
  13. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I second what heavy4x4 said, make sure theat all of the tension is released from the rear of the truck. Chock the front tires, realease the e-brake, put the tranny in neutral and try again. </font>
  14. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Yeah.... my buddy told me to jack up the rear and put it in netrual... binded driveshaft. BAH i shoulda thought of that.
  15. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    ok... well.... its not working . I jacked up the rear, took it out of gear, used a hammer, kicked it, screw driver as a pry bar cause I dont have one (broke my phillips) /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    What now??
  16. heavy4x4
    Aug 28, 2002
    3,270
    Dang dude, I've never heard of anyone having so much trouble...crappy.
    You do have the straps off, right? /forums/images/graemlins/tongue.gif /forums/images/graemlins/ignore.gif
    Did you call the shop and ask them what they did? I would do that...maybe for some odd reason they super epoxied the caps into the yoke instead of using clips to hold them in. Man, I sure hope that's not what they did (or anything close to what they did), but I'm running out of ideas. /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  17. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Go to the store and buy some real prybars. Once you have 'em, you'll wonder how you ever lived without 'em. /forums/images/graemlins/shocked.gif I use one for something nearly every time I go into the garage. /forums/images/graemlins/thumb.gif I like the ones that have a big plastic handle on 'em, sorta like a screwdriver handle. They come in various sizes. /forums/images/graemlins/cool.gif
  18. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
  19. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I emailed the mechanic, and he says sometimes they can get stuck pretty bad. He says he has a bigass 3foot long prybar with the plastic handle that looks like a screw driver-- i guess like what you are talking about.
    I guess i can get me one of those and see how that works out.
    ps. yes i do have the 4 bolts and straps off. /forums/images/graemlins/rolleyes.gif
    Thanks guys
  20. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Just remember not to smack on the u-joint cup hard enough to break the ear off of the yoke that holds the joint in the proper place. If you do you'll have to get a new yoke or do a little back-yard engineering like I do and weld a piece of washer on the yoke to hold the joint from moving side to side /forums/images/graemlins/grin.gif.
