cant get spindles off?!?!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mxrcr589, Dec 1, 2003.
  1. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    alright im trying to replace my ball joints and u joints and i cant get the spindles off???? I got the six retainer studs and lock nuts off, and have beaten the crap out of it and i cant seen to get them off, does anyone know any good tricks, i only have a little torch, which isnt working.
    also after i get the spindles off, the axle shafts should come right out right? or is there a c clip i have to take off?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I had the same problem on a buddies of mines truck. Ended up having to take a punch, and pound out the 6 pressed in studs, then hit the spindle with a rubber hammer really good and they popped off. Worth a try /forums/images/graemlins/thumb.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    smack the spindle where they sit up against the knuckle on the flat mounting edge, some pblaster, maybe a small chisel to wedge between the knuckle and spindle to move them apart..
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look closely at the knuckle itself and you'll see a notch at the outer edge that provides a place to smack the back of the spindle flange with a large punch. /forums/images/graemlins/cool.gif
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    What they said...just keep pounding on it. I used a wood block and hit it with a 3 pound hammer. They were free after a couple of whacks.
    And yes, once the spindle is off, the axleshaft will slide out. No c-clips in the front axle.
  6. mxrcr589
    Apr 17, 2003
    148
    poop
    got em off thanks for all the help
  7. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Get a slide hammer with the spindle adapter. They will come off in a few seconds. /forums/images/graemlins/thumb.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Rent it at Autozone if you want to do it that way. /forums/images/graemlins/thumb.gif
