Cant get tailgate open....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Sep 3, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    I was "rebuilding" my tailgate and before I put the window back in I thought I would shut the tailgate and make sure everything worked as it is supposed too. Well everything works great, but now my tailgate wont open[​IMG]!! Is there a switch or something I can hit insid the tailgate to get the gate open. I was thinking since the window isnt in maybe it didnt trigger whatever it usually does when it gets down to a certain point to allow the tailgate to be opened. I just dont know where that trigger is! Any help is appreciated!! thanks!!
    Oh yeah and just a tip....DONT SET YOUR GLASS ON THE GRASS!![​IMG] I sat my window on the grass (out of the way, no one could accidentally step on it, you know). Well I went to move it after a couple of hours later and when I did, the grass is now burned in the shape of my rear glass[​IMG][​IMG]!!!! To bad it wasnt in the shape of a bowtie[​IMG]!!!
  2. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Check out my PM to you.
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    There is a rod in the center that the glass pushes down and allows the handle to pull in the flaps. I use a small screwdriver toi push it down
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  4. tRustyK5
    Jul 23, 2000
    36,185
    1,393
    E-town baby!
    Also if you have the inspection cover off look for two small rods heading to each side of the tailgate. pull each one in towards the center of the gate and it should open.
    Rene
  5. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Got it!! Thanks guys, after I went back out I found the rod in the center once I started looking at it a little more carefully. I was also going to put on the outer window seal for the tailgate that I got from JCwhitney.....it didnt fit for sheeiiiiitt!! Thats what I get for trying to save a couple bucks!! So I'm sending it back and ordering one from Cheyenne P/U
