Can't get the daggum harmonic balancer off...help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Aug 29, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Can\'t get the daggum harmonic balancer off...help?
    Well, I've got the puller on, and I'm giving it everything I've got and it ain't budgin. Can anybody who's a psychic mind reader tell me what I'm doing wrong? Thanks
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Can\'t get the daggum harmonic balancer off...help?
    are you using a 3-jaw type puller or one that screws into where the pulley wheel bolts too?
  3. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Thanks for the quick response. I'm using the one that screws to where the pulley wheel goes. It's turning the crank, is that a real bad thing? But it won't come forward/loose. Do I have to set the timing again now that I've turned the balancer/ crank? And do you have any tips on how to get this pieceshit off? Thanks again
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    what i did when i redid my dads a few weekends ago is i had to fold a rag a few times and put it around the balancer and grabbed the rag and balancer with a pair of vice grips just tight enuf for it not to come off when your loosen it up. As for timing it, just follow what the book says to do and you'll be good. When reassembly, align the timing marks should be as followed: with No. 1 cylinder at TDC, your crank gear mark should be at 12 o'clock and the cam gear mark should also be at 12 o'clock, also double check rotor to make sure your are at TDC at No. 1. Then rotate the crankshaft one full revolution (No. 6 should be at TDC) the crank gear mark at 12 o'clock and cam gear is at 6 o'clock. Hope this helps.
  5. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Okay, I have now stripped all three holes out being the moron I am. Is there another kinda puller I can pick up tomorrow? I've also stripped out the bolts that came with the puller that I rented from Autozone. Are there any other alternatives to pulling the balancer off? I can take the old one off of my TBI motor so I'm not screwed totally, as long as I can still get this one off. Thanks for your help Jeff
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If you can get ahold of one, try the 3-jaw wheel puller, reverse the jaws and pull from the inside.
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You can put some vicegrips on the flexplate to jam it up. This is what I usually do. Good luck.
  8. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    I've got some nice new shiny vicegrips I need to dirty up a lil, can someone explain how to 'jam it up'? I think I'll give it a whirl.
  9. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    On the back of the engine, underneath. There may or may not be a cover between the tranny and the engine. If there is, pull it of and then you can see the flexplate or whatever you have. It will be a large round thing on the back of the engine with teeth all the way around. Put the vicegrips on it and when it rotates, the vicegrips will move up to the engine and stop it from moving more. Once you get under there it should be straitforward. Good luck with it.
  10. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    i take it you have the big bolt out of the harmonic balancer?? you might want to squirt a little lubricating oil in there, maybe it will loosen it up some? i've never really seen one stuck on there.
  11. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Okay I see what you are saying about the flexplate jammin thing. Last night my buddy used a crowbar to keep it from turning, I couldn't turn it after a couple of half rotations. I then tried to position the ratchet where I could stand on it to move it. That worked a couple of times but then I had to bounce on it to move it and then of course the ratchet broke shortly after. Anybody in Oklahoma that can take it off for me /forums/images/icons/frown.gif I'll give ya $30 and make some burgers and get some beer too
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Holy crap. That thing must be on there. You could try heating it up with a torch. That might work.
  13. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Stupid question but did you take the center bolt out of the crankshaft? I have not seen you mention doing that
  14. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    I was goign to say that too, also I had a Furd i did the same thing to, fought it for 2 days, ended up being I didn't get the washer behind the bolt out when I pulled the bolt.
    Boy I felt like a dumb A$$!
