cant go over 25 mph... wtf
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Jan 15, 2003.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I finally got to drive the truck on the road...
    and it shakes from the front end like 3 inches back and forth....
    I can do up to about 20.. but as soon as i try to go faster.. wobble like HELL.... I tried doing 30 to see if it woul;d go away.... I couldnt stay in my seat!!!
    I cantdrive it...
    74 k5
    350/th400/np203
    d44/14 bolt w/4.10's
    16/38x15 on steel wheels...
    Les Schwab balanced the best they could...
    Front axle has new ball joints.. and had no problembs up to 80 mph on the 35's...
    WTF!!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Sounds like Death-Wobble. Make sure all your tie-rod ends are 100%. Even slight wear can instigate the condition. A worn steering stabilizer can also be the problem.
  3. reddog64
    Nov 9, 2000
    3,325
    brand new steering stabalizer /forums/images/graemlins/thumb.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Aaron doesn't have a D60 (yet...) so Butch's method won't work. I'd also say tie rod ends, maybe run a dual stabilizer.
    Rene
  6. reddog64
    Nov 9, 2000
    3,325
    omg... rene it is bad...
    I mean i dont have to hit a bump or nothing.. it's soooo bad I can see the truch shaking back and forthe 3 inchs.. like 6 total... no exagerations here... /forums/images/graemlins/crazy.gif
    I can hardly keep my foor on the pedal...
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Dude...read "Butch for president". I just went through this...easily as bad, 25 mph max, slightest bump and my ass would be sucking up upholstery before it even started.
    On the D60 $3 worth of fender washers fixes it right up. On a D44 you're looking at real parts that are worn. The larger rubber is setting it off...
    How is the toe-in set?
    Rene
  8. reddog64
    Nov 9, 2000
    3,325
    i donno.. but the oil all over the place means i just found out the front main seal is SHOT TO HELL /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    doh i dint see that /forums/images/graemlins/blush.gif
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Did you put in a new lift kit to fit the bigger tires? If so, did the front springs have an angled shim on them to improve the U-joint angle at the front diff? Those shims remove caster angle and can cause massive death wobble. /forums/images/graemlins/frown.gif Just a thought...
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Sorry to hear that Aaron...when it rains it pours /forums/images/graemlins/crazy.gif
    Rene
  12. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Wheel bearings...bent rim maybe
  13. reddog64
    Nov 9, 2000
    3,325
    brand new steer wheels powder coated from schwabs... the balanced them.. the best they can.. no front drive lin ein.. i do have a 4 degree shim up front, maybe 3 degree...
    NO Sh!t Rene... (not trying to be a smart @ss...) I need to catch a break...
    To top it off I have to find a new place to live too.... /forums/images/graemlins/angryfire.gif
    I will NEVER live with another roommate!!! (at least a irrisponsible one) /forums/images/graemlins/1zhelp.gif
  14. u2slow
    May 9, 2001
    2,217
    BC Canada
    A can't remember what Chevy has for caster, but its not more than 5* max. You can see how 3-4* shims negates most of your caster. A taller tire is are less forgiving (more leverage and more sidewall to flex), so what was okay with 35's might not be okay with 38's.
    Ditch the shims - even if it means taking on the front driveshaft temporarily just to see if it fixes the problem.
  15. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Bad ball joints and/or worn DRE's and/or worn TRE's will contribute to C10 and D44 DW. A steering stabilizer may mask the problem, but it is not the "cure". I would suggest going through and checking your entire front end.
  16. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The shims are most likely the culprit. /forums/images/graemlins/frown.gif The front end needs a few degrees of caster or the tires will start wobbling like a bent wheel on a shopping cart. /forums/images/graemlins/shocked.gif
