Can't Login from home
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990SilveradoK5, May 16, 2001.
  1. 1990SilveradoK5
    1990SilveradoK5 1/2 ton status
    Jan 2, 2001
    185
    Napoleon, OH
    Can\'t Login from home
    I make it a point to spend much if not all of my lunch hour catching up on the board.
    However while at home I have not been successfull loging in. I always receive an error message informing me that username/password not valid, or something like that.
    Alittle history, I had created a username SoonToHaveAK5 prior to purchasing my 1990 and once I owned one I had Steve blow that one away and I created 1990SilveradoK5. When I was SoonToHaveAK5 I could login from both work and home. Is my confuser at home just confused, what can I do?
    I have cleaned out all of my Cookies in an attempt to correct the problem with no success.
    <A target="_blank" HREF=http://1990silveradok5.coloradok5.com/>http://1990silveradok5.coloradok5.com/</A>
    Gone Large and Loving It.
    Keith
  2. shane
    shane 1/2 ton status
    May 6, 2001
    162
    Prince George, BC, Canada
    Re: Can\'t Login from home
    only thing I can think of is that you could be logged in at work and trying to log in again from home. Just make sure you log out at work.
    You probably do but it's all I can think of unless you want to create another profile?
    Just keepin it Canadian[​IMG]
  3. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    Nope, it won't even give me the login screen. It must find a previous password or something and tries it. All I do is hit login and it gives me the error.
    Keith
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    delete all of you temporary internet files, and your cookies. it's possible you cookie is corrupt...
    <font color=blue> Jeff </font color=blue>
    [​IMG][​IMG]
  5. RAZORBLAZER
    RAZORBLAZER Registered Member
    Apr 24, 2001
    5
    nw arkansas
    if you have ever installed that "gator" automatic login and password tool it will screw you up, since you can't always use (or don't want to use) the same username and password on different sites. my mother put it on hers and it took me a while to figure it out because it doesn't always show up it just tries to log you in with whatever name you have in gator.
