cant make up my mind 4" vs. 6" lift
Discussion in 'The Garage' started by 84CUCV, Jun 13, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    This will be on a 1ton chevy p/u. Dont care about cutting fender. I would like to be able to use my stock driveshafts for now. Will be running 38s. So 4 or 6? Do a lot of you have a 4 and wish you went with a 6? Nothing over six. would like to keep it somewhat low. Just want to hear what some of you have to say.
    thx mike
  2. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    4 inch
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I've ran 38.5's on a 4" lift, 4" lift + 2" body lift and 6" lift + 2" body lift. Ultimately I like the 6" + 2" that I'm currently running. I thought I wanted a lower setup as well but due to the mud and trails we run over here a taller lift was needed. My approach angles were not very good and I did not want to move my axles.
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
  5. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I put in a Rancho 4" on my K30 and ran 38.5" Mudders no problem. I say 4".
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I have 6" superlift and 1" zero rates in the front... and still rub... however I will trim but there is a limit I will trim to.. I want to keep my inner wheel wells.... :crazy:
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK i think its going to be a HD TC 4" lift thx
  8. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    293
    Truckee, CA
    In that case, go 4" for sure
