can't open either end!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Feb 13, 2002.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    can\'t open either end!
    I can't get my hood or tailgate open!
    now I'm frustrated!
    When I pull the hood release lever, there's no resistance, like it got disconnected somehow. So how do I open the hood to fix it?
    the tailgate doesn't have a key mechanism, and the handle inside doesn't work, there's way to much resistance, like it's jammed or something, but I can't see inside well enough to figure out what went wrong, andy suggestions on either one?
    83 k5 originally diesel, now 350, 700-R4 12 bolt rear, 33x12.50 BFG Trails (yuck), desperately seeking a lift
    sometimes nothing is a real cool hand
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Re: can\'t open either end!
    It sounds like the hood cable is either broken or disconnected at the hood latch. What I would do is make a 'tool' that is sort of L shaped and slide it under the hood so it goes just behind the latch. You should be able to feel the latch mechanism there and then using a little persuasion push it towards the driver's side which will release the latch.
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Try pulling the release for the hood and then giving the front of the hood a good thunk with the palm of your hand. I have to adjust mine every once in a while, especially after wheeling.
    For the tailgate, grab a 1/2" wrench and crawl into the back. At the top corner on each side of the tailgate there are two bolts that hold the latches to the bedside. Unbolt the latches then go out and pull open the tailgate. Once it's open try opening and closing without latches...does it hit anywhere? Often the box sides spread and the thick steel guides will hit or rub. If it goes up and down cleanly open up the access panel and examine the latch mechanism for bent rods and other parts. Repair what you see adn then lube it up real good. If your box sides are leaning outwards you should look into the reason why and fix that. Once the box sides are OK then adjust the tailgate latches and try it out.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. 73 K5 Blazer
    73 K5 Blazer 1/2 ton status
    Sep 14, 2001
    483
    Madison, MS
    On the tailgate you can take off the access panel on the inside and access the rods that connect to the latches on ether side of the tailgate to get it opened. On the hood it sounds like the cable is broken and you will have to try to reach through the grill with a screwdriver to activate the latch. Let me know if this works.
  5. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    Thanks for the info, I've tried taking the panel off the back of the tailgate, but I can't see what's not working/bent, it's not like the tailgate is stuck from a bent box, but that the latching mechanisms jammed
  6. rampage
    Mar 20, 2001
    2,261
    73
    There is a rod that goes to each latch that are connected to the handle. You can remove these rods by taking off the clip with a screwdriver and manually pull on each one to release the latch.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    For the tailgate, look really closely at the linkage between the handle and the latches. There's an interlock that prevents the latches from opening unless the window is rolled all the way down. It's just a lever that the bottom of the glass pushes when the window is open. Make sure that it is moving far enough to allow the latches to activate.
