CAN'T POP MY TOP!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rockink5, Aug 7, 2002.
  1. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    CAN\'T POP MY TOP!
    First off, it's an 85 and the the top has never been off. Trying to take off for the first time. Have removed all bolt and worked around weatherstrip from the out side. The frikin thing will not budge. I have even tried a Hilift on the back just to see if I could give it a little UUMF...... no dice, any suggestions?
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Re: CAN\'T POP MY TOP!
    There are two bolts that go up into the top behind the inner panel in the back. Did you take those out?
  3. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    Are they hidden? If they are, then no. Didn't know about those /forums/images/icons/tongue.gif
  4. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Yea, take the panel off in the back and you should see them
  5. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    The bolts mount from under the bed rail and screw up into the top/cap back near the tailgate on both sides.
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    And you don't need to put them back in.. /forums/images/icons/shocked.gif
  7. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    nah.. i didnt put mine back in either...
    besides one was ripped out...
  8. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    COOL!!!! Thanks, all ready to pull it off tomorrow night. That was the problem. I didn't know about those two bolts.
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Try to pop it from the inside. I was able to get mine loose for the first time by standing in the bed with my back up against the inside of the top and pushing with my legs. If that doesn't work, try some boards and a jack inside. Prying around the outside might mess up your seals and they are kind of pricey to replace.
  10. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    yeah i agree, once you get all the bolts out inculding the hidden 2, just stand in the bed and push up with your back/shoulders, theres a lip where the cab meets the top, so when you're removing it you need to push up from inside at the cab while someones at the back pulling it, it doesnt just slide off like the broncos do...much better design in my opinion, mine comes on and off and it doesnt leak with the 17 yr old seal! my friends bronco leaked the first time he took it off and it still drips occasionally
