Can't remove brake disc from 1987 3/4-ton 4wd Suburban
Discussion in '1936-Present Suburban' started by airheadpilot, Aug 24, 2004.
  1. airheadpilot
    airheadpilot Registered Member
    Aug 23, 2004
    19
    Can\'t remove brake disc from 1987 3/4-ton 4wd Suburban
    One of my brake discs is in poor shape - it's heavily grooved and needs to be replaced. I have the replacement rotor and am in the process of pulling the bad one off the hub. I've removed the lockout hub, loosened and removed the locknut, and now I seem to be stuck. There is what appears to be another locking ring with four male dogs at 90 degrees from each other. It has lots of little holes drilled in the surface. I have the special tool and can turn it. It turns with some resistance, but doesn't appear to move down the shaft. I can't see any circlip or snap ring holding it in place. The rotor is now loose and wiggles but is clearly still being held in place by something. The only thing I can see is this locking ring, but clearly I'm clueless on how to get it out. My Hanes manual is spectacularly unhelpful on this point. What am I doing wrong? /forums/images/graemlins/1zhelp.gif
    Thanks!
    Andrew in Belmont, CA /forums/images/graemlins/burb.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Can\'t remove brake disc from 1987 3/4-ton 4wd Suburban
    Try and grab that locking nut with a pair of needle-nose pliers to be able to see if it is actually coming off the spindle or if the threads on the spindle are stripped. That last locking nut that you are talking about is all that is left to remove to be able to take of your hub/rotor assembly /forums/images/graemlins/thumb.gif
  3. airheadpilot
    Aug 23, 2004
    19
    Got it - thanks! I missed the groove for the lock ring in all the grease. Once I cleared that out it became obvious. Now I just need to find a local shop that can press the rotor off the hub and press the new one on.
    Thanks!
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    big f'ing hammer and a big diameter punch and the lug studs will pop right out and back in /forums/images/graemlins/thumb.gif
  5. airheadpilot
    Aug 23, 2004
    19
    Really? (!) Is that all that holds the rotor to the hub assembly, or do I also need to do something else to separate the two?
    Andrew /forums/images/graemlins/burb.gif
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Well, the rotor is held onto the hub via the lug studs if that is what your meaning.
  7. airheadpilot
    Aug 23, 2004
    19
    Thanks - I didn't realize that. I couldn't see whether it was also pressed on to the main circumference of the hub. I appreciate the advice and should be able to whip it out this afternoon after work. Sucks being a neophyte sometimes...
    Thanks!
    Andrew
